TM700 or HMC40 - which is better in low light? at DVinfo.net
Panasonic AVCCAM Camcorders
Old November 18th, 2010, 07:43 PM   #1
The title says it all - which camera is better in low light?
Herm Stork is offline   Reply With Quote
Old November 18th, 2010, 08:43 PM   #2
I own both, and haven't done extensive testing, but would say they're basically equal. In some situations, the TMC40 might have a slight edge.
Interestingly enough, both of them perform better in low-light than my Canon 7D with anything smaller than an f1.8 lens.
Dan Carter is offline   Reply With Quote
Old November 18th, 2010, 10:22 PM   #3
now that's very surprising about the the 7d Dan
everything ive heard actually says the tm700 is actually a tiny bit better in low light than the 40
Tom Bostick is offline   Reply With Quote
Old November 18th, 2010, 11:49 PM   #4
Technically, with it's f1.5 lens the TM700 should best the HMC40. However, at 1/30 sec shutter, I've found 18db with the TM700 to be unusable where the HMC40 is fairly noise free at 24db. The TM700 has "Color Night Mode" which requires only 1lux light, but any movement and the clip is doomed.
I'd be interested to see if other's mileage varys.
