AG-HMC80 firewire output at DVinfo.net
Panasonic AVCCAM Camcorders
Old November 8th, 2010, 04:05 PM   #1
Can anyone confirm if the date/time stamp comes through the firewire out put on this camera? I know it does not on some Panny cams.
Carl Sobeck is offline   Reply With Quote
Old November 8th, 2010, 05:20 PM   #2
Hey Carl
Are you sure the 80 has a firewire output??? Being a card based camera I figured they would omit it????
I haven't seen any mention of firewire in the specs????
Chris
Old November 8th, 2010, 06:22 PM   #3
Yes, it has the following in/output jacks:
Component: BNCx3 (x1 Output)
Composite: BNC (x1 Output, shared w/Component)
HDMI: HDMI (x1 Output)
FireWire: 6-pin IEEE 1394 (x1 Input/Output)
Line/Mic: 3-pin XLR (x2 Input)
Microphone: 3.5mm Stereo Mini (x1 Input)
Audio Out: Pin Jack (x2 Output)
Headphone: Stereo Mini Jack
USB: USB 2.0
Camera Remote: Super Mini Jack for Zoom, Mini Jack for Focus and Iris
Old November 30th, 2010, 01:31 PM   #4
Hey Carl
Chris
According to the manual, the HMC80 uses the Firewire port while in DV mode only. It is not used at all when in AVCHD mode.
Blog
Jordan Nash is offline   Reply With Quote
Old March 7th, 2011, 07:44 PM   #5
Re: AG-HMC80 firewire output
How do you get the SDHC cards into FCP? Do I need a converter or card reader or what?
in AVCHD I just plug a USB 2.0 in and run Log & Transfer?
thanks.
Jimmy Mehiel is offline   Reply With Quote
Old March 7th, 2011, 11:25 PM   #6
Hi Jimmy
Regardless of NLE, surely you simply copy the contents of the "Stream" folder onto your drive??? I have a built-in card reader so I find it's easier to just take the card out and pop it into the drive and copy the files onto one of my portable drives. In DV Mode the folder will have AVI files not MTS
I assume that FCP can import Panasonic MTS AVCHD video files as well as DV-AVI????
Chris
Chris Harding is offline   Reply
