#121 |
I calculate the diagonal of a 16:9 crop of the AF100 sensor at 19.8mm, or .75 inches.
(The diagonal of a 16:9 crop of the 5DII is 41mm, for comparison.) |
#122 |
The same article mentions imaging area of 17.3 mm × 13.0 mm, so that seems like a starting point for comparisions.
2/3 is 8.80mm x 6.6mm, 1/3 is 4.8mm x 3.6mm, Standard 16mm 10.26mm by 7.49 mm. However, don't take the 2/3 sensor sizes as fixed, the 16:9 sensors are different, for one Sony camera it's 9.58 mm x 5.39 mm. Yet another example: the SI 2k is 10.24x5.76mm @ 2k. |
#123 |
I shouldn't have said "AF100" sensor. I took the size off wikipedia, which may not reflect the full 4/3 standard. As pointed out the logical chip may be 16:9 with a 22.5mm diagonal (if the 4/3 standard allows any shape with a 22.5mm image circle)
So it seems 35mmish is "in the ball park" for the AF100, and otherwise we're just guessing. |
#124 | |
So what about AVC-Intra 100 to Compact Flash cards? You simply don't need P2 to record 100Mbs video these days. The nanoFlash is living proof that a 100Mbs video bitstream can be reliably recorded to fairly basic spec Compact Flash. The new Canon has gone for Compact Flash - why does the Panasonic choice have to be either (expensive) P2, or SDHC - why can't the Panasonic camera record AVC-Intra 100 to CF? Or would that have their marketing people giving the loudest "waaah!"? |
#125 | ||
#126 |
Contributor
#127 | |
#128 | |
What's technically possible, and what is marketing strategy, are two wholly different things and it wouldn't surprise me if for the latter reason Panasonic were keen to keep AVC-Intra linked to P2 and AVCCAM linked to SDHC. It just needs to be absolutely clear that technically a 100Mbs stream like AVC-Intra can be reliably recorded to far cheaper media than P2. For their higher range products, P2 will no doubt still make more sense than SDXC would. For a sub-$10,000 camera like this, AVC-Intra to CF or SDXC would be far and away the best compromise. |
#129 |
Here are some size comparisons compiled for Red
Some of these may be wrong, but it gives a rough comparison to 4/3 2/3" - 3072 x 1620 - 3K 10.1x 5.35mm MX native 16:9 aspect ratio, approx 11.5mm diagonal, 3.3 micron pixels, approx: 5 mpx, 3.75 FOV crop factor. R1 - 4520 x 2540 - 4K 24.4 x 13.7mm Mysterium native 16:9 aspect ratio, approx 28mm diagonal, 5.4 micron pixels, approx: 12mpx, 1.5 FOV crop factor (APS-C). S35 - 5120 x 2700 - 5K 30x15mm MX native 16:9 aspect ratio, approx 33.5mm diagonal, 5.4 micron pixels, approx: 14mpx, 1.25 FOV crop factor (APS-H). FF35 - 6000 x 4000 - 6k 36x24mm Monstro native 3:2 aspect ratio, approx 43mm diagonal, 6 micron pixels, approx: 24mpx, 0 crop factor (FF DSLR). 645 - 9334 x 7000 - 9k 56 x 42mm Monstro native 4:3 aspect ratio, approx 70mm diagonal, approx: 65 mpx, 0.6 crop factor (MF). 617 - 28000 x 9334 - 28k 168 x 56mm Monstro native 3:1 aspect ratio, approx 177mm diagonal, approx: 261 mpx, 0.25 crop factor (MF). Crop Factor refers to Field of View (FOV) crop factor, or Focal Length Multiplier (FLM), referenced to Full-Frame 35mm. APS-C (Canon1.6, Nikon1.5): Canon Betacam, 550D, Nikon D300s, D90. APS-H (Canon 1.3 crop): Canon 1D MkIV. FF DSLR: Canon 1Ds MkIII and 5D. Nikon D3s/x and D700. MF (Medium Format): various Hasselblad, Leaf, Mamiya, Pentax, Phase One. |
#130 |
Anything but proprietary storage. There's little benefit to the small SD size in a camera like this.
#131 | |
#132 |
UDMA CF is necessary with Canon CF to reliably do 35mb/s.
I've been looking at GH1 movies and I have to say the color is nice. Seems very well controlled, especially skin tones. Canon can get a little pink or go too dull at times(with Caucasians). That chip with a proper video anti-aliasing filter should be very nice in the AF100. Especially if the chip is read faster. I wouldn't want to buy 4/3 lenses, but it doesn't sound like that will be necessary. |
#133 | |
Something like Sandisk Extreme III (much cheaper) is rated to 30MBs - or 240Mbs. That's still nearly 7x the speed of the 35Mbs codec, and about 5x the speed of the 50Mbs codec (as used by the new Canon). Now I take the figures with somewhat of a pinch of salt, and ones which need a big safety margin to be allowed. But in real world usage that speed of card is approved with the nanoFlash for the 100Mbs datarate - so about 2-2.5x seems to be an adequate safety margin. And if the card can record 100Mbs reliably in the nanoFlash, there is no reason why it shouldn't do the same for AVC-Intra 100 in a Panasonic camera. As far as reliability goes, Compact Flash is relied upon by the vast majority of the professional digital stills photo industry. The only failures I've heard of first hand was someone who bought a very cheap, unbranded card - needless to say, he sticks to decent brands now, with no further trouble. |
#134 |
The point I was trying to make was that the speed rating alone didn't matter for avoiding buffer overrun. The card needed to be UDMA.
I do wonder if more than 50 mb/s is necessary. I am curious if current CF cards can really do sustained 100 mb/s. |
#135 | |
Still not convinced? Just take a look at the relevant Convergent Design website page - Media | nanoFlash | Video Recorders and Converters . You can't just take any cheap unbranded card and hope for the best, but that reference gives a range of cards qualified by CV for given bitrates - all the way up to 280Mbs! The nanoFlash has been in use for quite a while now - if CF usage for recording sustained 100Mbs was a problem, we'd have heard a lot about it by now. |
