#31 |
Hi Guys
That's not really moire with the picket fence but actually the vertical lines breaking up when you fast pan!! CMOS chips do that and there IS a warning about fast movement on the HMC40 brochure so it will be in the manual as well. However in practice you would never pan that fast so I doubt whether it's worth worrying about!! Moire doesn't come from the chip type but is quite common with all sensors. With my HMC72's a large brick wall got in the camera view and you can see the moire pattern clearly. And that's with CCD chips!!! Generally it's best to just avoid any surfaces with repetitive patterns!!! Chris |
#32 |
I often pan with fast moving vehicles as they pass by. Does this problem of aliasing or moire only exist when panning against repetitive looking static objects then? Or, should I try not to pan at all using the HMC40? Seems like that couldn't be the case.
Chris |
#33 |
Well, I think with the picket fence I should have used a faster shutter speed. I didn't realize that in full auto the default shutter speed is 1/60. But the wavy lines on the green roof and the "blooming" effect from a striped shirt and a window with vertical blinds in other clips should NOT be happening at any shutter speed while I'm standing dead still. Like I've said before, I've owned a slew of camcorders in the last six years and this is the first one I've ever had these problems with. My Sony V1U is a cmos sensor and I've NEVER had problems with moire or blooming or vertical-line breakage. And the noise is not an AVCHD thing because my Sony HDR-SR-11 and HDR-XR500V handycams don't do it either.
I'm with Chris R. - why the heck would you want a videocamera you couldn't pan with? I mean, I go out to accident scenes, house fires, etc. I'm going to have to pan sometimes. I don't want to have to worry that I'm gonna get garbage footage from a $2,000 videocamera. |
#34 |
I wonder if these problems can be adjusted out by altering some of the scene file items? I have no idea what most of them are, but I seem to remember reading that some of those items might be able to help.
As far as upping the shutter speed, it didn't appear to make a bit of difference in my videos. Does it seem like it did to you guys? YouTube - Panasonic HMC40 Zoomed In Aliasing - Moire Sherri, I wouldn't think the camcorder defaults on 1/60 shutter speed. I would think it would pick a combination of shutter and iris for optimal exposure automatically. I think if you're shooting in full auto and you switch over to manual, giving the brightness of what you're shooting, you'll see the shutter speed and iris be different given different conditions. But, I could be wrong too. I just think when I've switched from auto to manual before, I've looked at the gain, it it displays if it's applying any gain or not. I discovered that while shooting with one overhead light, a max of 12db of gain isn't enough to expose properly. All my low light videos were shot at 24db, because I'm guessing the camera's sensor size isn't big enough to expose properly at low light. But, everyone's said this, which is another reason I'm guessing I won't need an nd filters for this camera in broad daylight either...I decided on just a uv filter and polarizing filter. Chris |
#35 |
Barry Wan Kenobi
Just catching up on this but -- there's no aliasing or moire going on in that video. You're shooting at 1/2000 shutter speed! Of course that's going to make everything look stuttery -- you've removed all the motion blur.
You should *always* be using 1/60th when shooting 1080/60i. That's the only way you'll get natural motion rendition. The shutter speed should normally never be changed when using a video camera; the shutter is not used for controlling exposure. You use the iris, and ND filters, for controlling exposure. The only times you change shutter speed are when you're going for a specific effect, such as the "Saving Private Ryan/Gladiator" effect, or streaky smeary blurring. If you're shooting 24p, 1/50th is an appropriate shutter speed. If you're on 30p or 60i or 60p, 1/60th is the right shutter speed. If you're shooting 60p with the intention of using it as slow-mo footage, then you'd use 1/120. Other than that, leave the shutter speed alone, if you want your motion footage to accurately convey motion. |
#36 | |||||
Thanks a ton for the help Barry...I would have had terrible footage and been really pissed. I look forward to your responses to the above... Chris |
#37 | |
Yes, you add ND filters to keep your DoF (though a 1/4" chip is not going to be very shallow to begin with). In fact as Barry discovered the HMC40 does not actually close beyond 2.4 (correct Barry?) and actually slides in ND filters when you close the shutter more than 2.4. This is not a common thing for a video camera. In fact it is the first time I have heard of it. It makes sense though as the 1/4" chip has crazy DoF (not shallow) and by sliding in ND filters it help keep what shallowness it does have. Make sense? |
#38 | |
In regards to the shutter speed, so is it better then to have the lowest possible shutter speed possible to stop the motion, but no higher, since it's processing it so often? Any higher and I'm only hurting the video quality because it's so processor intensive? Chris Chris |
#39 | ||||||||||
Barry Wan Kenobi
1080/24p has more detail than 720/24p, 1080/30p has more detail than 720/30p, but 1080/60i and 720/60p are about comparable; the additional temporal resolution of 720/60p makes up for the additional spatial resolution of 1080/60i. However, the advantages of progressive over interlaced make 720/60p my choice for live-action or to-be-slow-mo'd footage. Quote:
#40 | ||
Barry Wan Kenobi
It's not so much for DOF, it's to avoid diffraction. Tiny-chip HD cameras are far more prone to diffraction issues than larger-chip cameras are. On a 1/3" you could see diffraction as early as F/4 in the red wavelength, and an HVX200 would have some serious resolution loss at f/11 because of diffraction. The HMC40 has much smaller chips, and 4x as many pixels, making it *very* susceptible to diffraction. So, this system keeps the iris open as much as possible for as long as possible, helping to avoid the territory where diffraction sets in and starts to overly soften the picture. The downside is, you will likely never know what your true f-stop is. Think of it more like t-stops; the amount of light being transmitted is changing, even if the actual f-stop isn't mechanically changing for that two-and-a-half stop range. |
#41 | ||
Barry Wan Kenobi
Use it for artistic purposes if you want, just do so on purpose, knowing that you're diverging from the typical motion look. |
#42 |
It should be noted that a lot of sports tends to be shot at 120 shutter. I have tried that on a HMC150 set at 720 60p 120 shutter and find I prefer the look of the shutter off (well actually 60 when at 60P).
I found 60P be good for showing legs running (as apposes to legs moving in blur) and not overly choppy. We're shooting Football at night and Hockey. 60P is what looks best for us at the moment, especially for hockey. I'm still testing for football. It might depend on the sport. With Hockey the puck can appear to leap across the rink when at a higher shutter. You need a bit of blur just to keep track of the puck (to much blur say 30P and it looks weird). High shutter speeds are like watching TV through a fan. As the blades spin by, temporarily blacking your view several times a second, they give the picture a staccato effect simular to what Barry mentioned. |
#43 |
You guys rock. I'm going to experiment with 1/60 and 1/120 shutter to see what looks best with the hmc40. I really appreciate all the help guys.
Chris |
#44 |
Here's some testimonial videos I put up on Youtube from my Glamis, CA dune trip.
YouTube - MCX-USA RZR Turbo Kit Customer Testimonial - Greg YouTube - MCX-USA RZR-S Turbo Kit Customer Testimonial - Cliff YouTube - MCX-USA RZR-S Turbo Kit Customer Testimonial - Doug YouTube - MCX-USA Prowler XTZ 1000 Turbo Kit Customer Testimonial - Jose YouTube - MCX-USA RZR Turbo Kit Customer Testimonial - Gary YouTube - MCX-USA RZR-S Turbo Kit Customer Testimonial - Brenda All of this whipped together as one video for the SEMA show that just ended...all rough cuts, very little editing done to make them look more professional. I'm very impressed with the camera, and I've found that my matthews tripod when shooting today is a huge help. I'm shooting out in UT today and the next two days, and using the tripod makes all the difference in the world for quality shots. I played it through component out as 1080i, even though I shot it in 720/60p, and it looked outstanding on the television today. Unbelievable actually. The exposure was spot on, colors at +1 chroma look great. So far, I'm very pleased with the camera. Chris |
#45 |
YouTube - HCR Racing UTV and Side by Side Long Travel Kits in Action
This was shot with the HMC40 in PH720/60P using the Panasonic .7x Wide Angle Lens and no nd filters all shot on a Matthews M25 Tripod. Sound was captured using the rode videomic with dead cat. Chris |
