Can you capture live via the 150's USB port? at DVinfo.net
Panasonic AVCCAM Camcorders
Old July 1st, 2009, 06:59 AM   #1
One thing about the new AVCHD cams is there is no longer a Firewire port. What are my options/quality for live signal capture? I'd like to use the tools that OnLocation provides, but don't know if I can with the HMC150.
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old July 1st, 2009, 12:29 PM   #2
Barry Wan Kenobi
Nope.
Best bet would be to look at HDMI streaming to an HDMI capture card or HDMI solid-state recorder. OnLocation doesn't yet support HDMI boards like the Intensity Pro, but I can only assume it's just a matter of time.
Old July 4th, 2009, 12:34 AM   #3
Look at Cineform. They support the Blackmagic board and dirert HDMI capture. Should look awesome.
Andy Urtusuastegui is offline   Reply With Quote
Old July 4th, 2009, 09:45 AM   #4
It's a pitty that AVCHD cameras don't allow for live capture via USB. There's really no reason not to include that capability with the cameras.
Robert M Wright is offline   Reply With Quote
Old July 10th, 2009, 02:00 PM   #5
Barry Wan Kenobi
There's plenty of reason to not include it -- USB protocol doesn't allow for it.
Firewire was developed with two protocols, A/VC and SBP2. A/VC is for Audio/Video Control, and is used for streaming video devices. SBP2 is "Serial Bus Protocol 2" and is for file transfer. USB doesn't support any sort of similar A/VC protocol. USB only supportes frame-and-packet transfer, essentially similar to SBP2.
Old July 30th, 2009, 09:57 AM   #6
how about watching live from PC, is it possible? Can I use for broatcasting live, I think not :)
Ahmet Toca is offline   Reply With Quote
Old July 31st, 2009, 09:33 AM   #7
Barry Wan Kenobi
Use an HDMI capture board, or an analog capture board, and then yes you could do it.
But it isn't gonna happen from the USB port.
Old November 6th, 2009, 02:30 AM   #8
USB video transfer
I have a related question.
I have a firewire 800 port on my apple but my firewire cable has gotten messed up. So can i transfer the footage to another apple which does have a firewire 400 port, then dump this on my hard drive and transfer it by USB to my apple? Will this cause any loss of quality/frames??
thanks
Payal Kapadia is offline   Reply With Quote
Old November 6th, 2009, 11:17 AM   #9
Once the footage has been captured and turned into a FILE, you can transfer the file anyway you like to another hard drive for editing without issue.
