Final Cut Express with HMC-150 at DVinfo.net
Panasonic AVCCAM Camcorders
Old January 20th, 2009, 08:34 AM   #1
I am looking to upgrade my camera but I am not ready to make the jump to Final Cut Pro - or at least my wallet isn't ready and I am wondering if Final Cut Express can log and capture files from HMC-150 or if I will need the Pro Version.
I use Final Cut Express for my HF10 and it works great but I am not sure if it would work for the HMC-150.
Mike
Mike Brice is offline   Reply With Quote
Old January 20th, 2009, 09:48 PM   #2
Anybody have any idea?
Mike
Old January 21st, 2009, 05:44 AM   #3
FCE4 appears to support AVCHD so you should be good.
Colin Zhang is offline   Reply With Quote
Old January 21st, 2009, 07:33 AM   #4
I don´t think FCE supports 720P 50/60
Remember, that English is my second language.
Hans Ledel is offline   Reply With Quote
Old January 21st, 2009, 07:53 AM   #5
Anyone with this camera that has tried it on FCE?
Just looking for some first hand confirmation.
Mike
Old January 26th, 2009, 12:46 PM   #6
Pretty sure it will transcode to Apple AIC codec.
Large files, quality hit and processing time.
Use Toast 9 to transcode (convert) the mpeg4 files to whatever QT format you want.
Johnny Clark is offline   Reply With Quote
Old January 27th, 2009, 09:46 PM   #7
Mike, I am using the 150 with latest version of FCE and it is working fine, there are some do's and don'ts that I have learned from approx 4 video projects that I have shot with the camera and edited.
Yes you can shoot with 720p 60 (not 30) and you have to use the HDV 720p AIC for ingesting. The biggest problem I have had is ingesting from the camera, this is a problem, so I purchased an inexpensive SD card reader and popped the SD card in it and then connected it directly to the Mac, with no camera in use. So far this has worked very well.
I am using an iMac with about 2GB of RAM.
Good Luck
Don
Home
Mike
Don Hambridge is offline   Reply With Quote
Old January 28th, 2009, 05:25 AM   #8
Appreciate the first hand experience.
Unfortunately, that means my wallet may be hurting a bit.
Mike
Good Luck
Don
Home
Old February 2nd, 2009, 12:30 PM   #9
I cant get the 720p 50 (HMC151 pal) material imported to FCE. Same problem?
Jens East is offline   Reply With Quote
Old February 28th, 2009, 10:48 AM   #10
how smooth is final cut express 4 on the timeline with the hmc150? i have found shooting 720p looks great on this camera...
Matthew Harris is offline   Reply
