Best 50/60 Hz HD Conversion at DVinfo.net
Open DV Discussion
Old July 12th, 2007, 06:07 PM   #1
What is the best software for converting 60 Hz to 50 Hz and vice-versa? I'm interested in something along the lines of Snell & Wilcox's Alchemist Ph.C - HD, a motion-compensated converter. However, the conversion can be done offline, so I don't require a hardware solution.
Jon Fairhurst
Old July 14th, 2007, 05:55 AM   #2
Algolith Algosuite 2
http://www.algolith.com/index.php?id=algosuite0
Louis Mostert is offline   Reply With Quote
Old July 14th, 2007, 04:11 PM   #3
Originally Posted by Louis Mostert View Post
Thanks! I'm not an After Effects user, but I will look seriously into this program.
Jon Fairhurst
Old July 15th, 2007, 12:25 AM   #4
It's the best software solution, I think.
It uses object based motion compensation. The results are totally pro.
Here is the algorithm it uses: CRC-FRC
CRC-FRC is an advanced frame rate conversion algorithm for high quality film and video temporal conversion. The core of CRC-FRC™ is a patented object-based motion-compensated frame interpolation. Because it is based on image objects rather that on blocks or pixels, CRC-FRC is able to more accurately estimate the true object motion. New images are created by motion-compensated temporal interpolation between two input images along the motion direction. This method produces higher quality images and smoother motion compared to simple frame repeat, temporal filtering, or conventional motion-compensated frame interpolation.
Old July 17th, 2007, 03:06 PM   #5
Perfect! This is just what I was looking for...
Jon Fairhurst
Jon Fairhurst is offline   Reply
