Can footage from an XL1s and PD150 be seemlessly interchange in post? at DVinfo.net
Open DV Discussion
Old May 11th, 2003, 08:03 AM   #1
I'm going to be doing an indoor shoot in a couple months as a second camera. I have an XL1s a the other camera is a PD150. Are there any settings on either camera we should be aware of to help insure a seamless mix in post? Is it even an issue?
Mark Argerake is offline   Reply With Quote
Old May 11th, 2003, 08:50 AM   #2
Check out this thread
http://www.dvinfo.net/conf/showthrea...&threadid=9504
Michael Chen is offline   Reply With Quote
Old May 12th, 2003, 09:45 PM   #3
Contributor
The PD150 will probably be a little sharper and less color saturated than the XL1s. White balance the two cameras together, then crank up the saturation and crank down the sharpness just a bit on the 150. You'll need a good monitor with an A-B switch to do this. Then you can do whatever additional color tweaking may be necessary when you edit.
Bill Pryor is offline   Reply
