How to deal with stroboscope effect caused by room lights at DVinfo.net
Open DV Discussion
Old May 23rd, 2007, 04:14 AM   #1
I recently shot some HD footage in a school using a PAL 1080i camera from Sony. Later, when editing the footage I noticed there was a slight stroboscopic effect on the material (a bit like what you see when shooting a CRT monitor or TV with a DV camera, but less pronounced). My guess is that it was caused by a difference between my capture frequency and some native frequency of the lights in the room. Is there any way in Final Cut Pro to correct for this. Is there a way to prvent the issue from ahppening while shooting, for example by adjusting shutter speeds or so?
david.
David Niemeijer is offline   Reply With Quote
Old May 24th, 2007, 02:01 AM   #2
If your camera has a "clear screen" feature, which is actually intended to allow the camera to sync with the flicker of computer CRT's, then that would solve the problem.
I ran into the same issue in New Zealand, using NTSC cameras under 50 Hz fluorescents.
The gelled tungsten lights we used helped mask the problem -- which went unnoticed until it was too late. That's one of the follies of rushing a setup.
By the way, there's a difference between working quickly and rushing. Rushing often leads to carelessness and mistakes.
Dean Sensui
Old May 24th, 2007, 06:24 AM   #3
Changing shutter speed can help, but it is not very likely to work. I have a method that works, but it won't work with most cameras. I can set the V1 to 1/30 shutter and shoot 30P so I still get the full framerate, but the motion blur is excessive for most purposes. No fluorescent light flickers as slow as 30 times a second, so 1/30 shutter will always work, but that's a really slow shutter and I would only use it in extreme circumstances.
Marcus Marchesseault is offline   Reply
