Wavy lines on my footage when panning. at DVinfo.net
Open DV Discussion
Old April 11th, 2007, 08:05 AM   #1
I've noticed that, in some of my footage that I'm editing with Adobe Premeire Elements 3.0, there is a wavy line (like old fashioned 'interference') at the bottom of my footage when I am panning, say at about lines 530 to 540 (PAL).
I've seen this issue in several clips but only when I am panning!
I've tried to crop the clip but the lines simply move up the footage, so it's obviously not a problem with the camcorder (I think).
What is causing this?
Martin
Martin Chambers is offline   Reply With Quote
Old April 17th, 2007, 04:50 PM   #2
Can you post a quick sample of whats going on... maybe a screencap if any.
Michael Ferreira is offline   Reply With Quote
Old April 19th, 2007, 03:47 AM   #3
Sorry I can't, wish I could.
When I run the footage, it's as though the bottom lines are out of sync with the lines above. Almost like what you see with interlaced footage on a PC except that it's one large step rather than 288 small ones!
When I pause the footage, the resultant still image is ok.
Any more thoughts?
Old April 19th, 2007, 10:25 AM   #4
Do you see those lines after exporting your footage and viewing it with another software? It might be just a display issue and maybe you don't need to worry about it.
Ervin Farkas
www.AtlantaLegalVideo.com
Ervin Farkas is offline   Reply
