Capturing Date and Time Info to AVI. at DVinfo.net
Open DV Discussion
Old March 31st, 2003, 04:27 PM   #1
I've been copying my Digital8 tapes to PC for editing and am having a hard time keeping all of the scenes in chronological order. I'm having to go back to the original tapes to verify when the scenes were shot, and if I've got them in the right order, which is an extremely time-consuming task. My problem would be solved if I could get the date/time stamps of the recordings embedded into the .AVI files when I'm transferring the tapes, but I can't find out how to do this.
There's got to be a way to capture this information, but then again I've never seen an avi player with the equivalent of the camcorder's "Data Code" button for viewing the date and time of the clip.
I've got a Sony DCR-TRV315 digital8 and am using Ulead's VisualStudio 6. I'm capturing through Firewire.
Rusty
Rusty Johnson is offline   Reply With Quote
Old March 31st, 2003, 07:46 PM   #2
I am not aware of anyway to do this. The best solution would be to build multiple folders to organize these clips.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old March 31st, 2003, 07:59 PM   #3
You could name the .avi files by date, or do what Nathan said and capture each different date into a different bin. You could also always make a paper list :)
alextaylor.org
Alex Taylor is offline   Reply With Quote
Old April 1st, 2003, 11:09 AM   #4
Images: 32
Might take a look at CatDV for logging and cataloging Digital Video.
Michael Wisniewski is offline   Reply With Quote
Old April 3rd, 2003, 06:53 AM   #5
RED Code Chef
For DV the date/time that is used for the original recording is in
fact on tape/file!!! The problem is that almost no program
seems to use this information (doh). I think QuickTime player shows
the information in the properties. I have written a small program
that can extract the information as well, but it is currently not
very easy to use. If you really need it I might be able to bang
something together for you quickly. If so, mail me at visuar@iname.com
Rob Lohman, visuar@iname.com
Old April 3rd, 2003, 07:10 AM   #6
Warden
Quicktime does indeed list it in the video properties.
Jeff Donald
Carpe Diem
Old April 3rd, 2003, 08:17 AM   #7
Is there an editing soft that could read/use the date/time on the DV avi file? I'd like to write some text on the video image, that contains the actual date/time from the avi file. Is that posible?
Cosmin Rotaru is offline   Reply With Quote
Old April 4th, 2003, 09:23 AM   #8
RED Code Chef
Not to my knowledge, Cosmin. Perhaps the more professional
NLE's like Avid support this, but I'm not sure...
Old April 4th, 2003, 10:05 AM   #9
Warden
Cosmin,
Cat DV 3.0 Pro might do what you need. It uses QT and reads many of the properties. I don't know about AVI's. You might try emailing there support to see how they are supported.
Jeff Donald
Carpe Diem
Old April 7th, 2003, 02:50 AM   #10
I found a litle (free) plugin for VDub (also free!). I didn't try it yet. I hope it works!
Old April 7th, 2003, 09:45 AM   #11
If you import DV with Scenalyzer, it will by default name the .AVI files with somename'DATE TIME.avi
It also chops up the DV stream into individual shots if you so choose (obviously needed for the above application)
Find it at www.scenalyzer.com
Was that what you were looking for?
Hans Henrik
Hans Henrik Bang is offline   Reply With Quote
Old April 9th, 2003, 09:23 AM   #12
RED Code Chef
Cosmin,
What plugin did you find? Does it work?
Old April 9th, 2003, 10:44 AM   #13
Hi!
Here is the plugin:
http://toonarchive.com/addframenumbers/
I think I found the link somwere on this forum! I'm not sure...
Anyway, didn't try it yet. I miss some spare time...
Old April 9th, 2003, 03:22 PM   #14
RED Code Chef
I don't think that this plugin will read information from the DV
stream. I think it just creates the information for you...
But ofcourse it is worth a try!
