Pedestals at DVinfo.net
Open DV Discussion
Old January 20th, 2002, 10:58 AM   #1
Pedestal/Dollies
Can anyone tell me how much I would expect to pay for a camera pedestal/dolly?
Also, is there anywhere in the UK that sells them?
Alternatively, are just wheels for an existing tripod available for a cheaper price?
Dan C. is offline   Reply With Quote
Old January 20th, 2002, 11:02 AM   #2
Hi Dan,
I thought they were called dollies?, Hague produce some and they are based in Nottingham URL http://www.b-hague.co.uk, they also produce Jibs and Cranes.
Hope this helps,
Ed Smith
Ed Smith is offline   Reply With Quote
Old January 20th, 2002, 11:13 AM   #3
Thanks for that Ed.
They seem to be called both pedestals and Dollies.
In one shop I was looking at, the ones whith vehicles attached where called Dollies and the ones with wheels were called Pedestals.
They do look rather expensive, are there any lower-specified models available anywhere or has anyone got any tips for attaching some wheels to my existing tripod, as I dont really want all the other features of the dolly (ie. the tripod bit).
--UPDATE--
After seeing some Pedestals on bhphoto.com - $50,000!, I now retract my opinion that the one on the above store is expensive.
Old January 20th, 2002, 02:16 PM   #4
Retired DV Info Net Almunus
Ed,
If all you're really looking for is a dolly (i.e. a set of wheels) for your current tripod I might start with looking at the brand of your tripod. Bogen/Manfrotto, for example, makes several models that mate to the design of their tripods' feet. Mating the feet to the dolly's wheel fittings will be a bit of an issue, hence my suggestion to look at your tripod's manufacturer first.
Here in the U.S. B&H Photo is a good place to start (bhphoto.com). Click "professional Video" and look for the link to "Tripods & Dollies".
Old January 20th, 2002, 03:23 PM   #5
Thanks for your post.
I have a relatively cheap, MIRANDA tripod.
I have seen a set of wheels that attach to the tripod on the above mentioned site, but I dont know if they will fit my tripod.
Is there anywhere where I might purchase individual wheels, which can be attached to my tripod?
Another query, does anyone know whether the HAGUE-PRO tripod on the website above has a hydraulic up/down feature?
If not, would I be looking at much more for a dolly with this feature? (if I was going to buy a proper dolly I would like it to have this feature because that way I am getting some improvement over simply a tripod with wheels)
Old January 21st, 2002, 02:11 PM   #6
Hi Dan,
As far as I am aware the Hague Pro Dolly does not have hydraulic up/down feature and that is why it is so cheap. If you are looking for one with that feature try this web site:
http://www.cke.co.uk/acatalog/CKE_Distribution_Tripods_35.html
Unfortunately these are not cheap coming in at around £2000!!
Hope this helps
Ed
Old January 21st, 2002, 02:23 PM   #7
Don't forget borrowing/renting a wheelchair.
Don't laugh...Robert Rodriguez shot "El Mariachi" that way.
John Locke
SursumFilms.com
John Locke is offline   Reply With Quote
Old January 21st, 2002, 03:43 PM   #8
Not just for indie films: for some scenes in Enemy At The Gates they used a wheel chair as a dolly too =)
Casey Visco
Glidecam Industries, Inc.
Casey Visco is offline   Reply With Quote
Old January 22nd, 2002, 10:03 AM   #9
Im not sure if a wheelchair would be a good idea, considering I will be using it a lot (once a week maybe).
I think I might just buy those B-Hague wheels for my cheap tripod.
When using a wheelchair, how is the camera attached to it?
Old January 22nd, 2002, 10:47 AM   #10
Typically the camera operator is sitting in the wheelchair and someone is pushing the chair. For some situations, notably smooth surfaces, it works as well as a tracked dolly and takes no time to set-up or tear-down.
Old January 22nd, 2002, 05:48 PM   #11
i have often scene a mounting head simply clamped to a bar of the chair...
Casey Visco
