avi file in Quicktime Pro on PC at DVinfo.net
Open DV Discussion
Old August 15th, 2006, 08:42 AM   #1
When I bring an avi file (captured from camera or generated in editor) into Quicktime Pro (on a PC) I get lots of artifacts and pixelating. This is happening on my two current PCs, but my recollection is that this did not happen on my old PC (which I no longer have). As a matter for fact, I have some mov files I created on the old PC using QT Pro that look fine.
What am I doing wrong? I recall something in the past about needing to download the "authoring" opting with QT, but I don't recall seeing that when I installed QT Pro on my new PCs. Do I need a special codec?
Current PC configuration:
Dell Workstation 380
Windows XP Pro
Two 3.4 GHz dual core Pentium D
4 GB RAM
500GB SATA harddrive
Primary editor: Vegas 6d
Primary avi capture sw: Scenalyzer
Quicktime Pro version 7.1
Regards,
Buddy
Buddy Frazer is offline   Reply With Quote
Old August 15th, 2006, 10:46 AM   #2
"When I bring an avi file (captured from camera or generated in editor) into Quicktime Pro (on a PC) I get lots of artifacts and pixelating."
This happens to me when I open a DV avi in QT. However, there's nothing wrong with the file, it's just that QT isn't displaying it right for some reason. If I export the avi, the exported file looks fine. Unless you use QT as a viewer, I wouldn't worry about it.
BTW, I think it has to do with the DV codec, if I open an avi with a different codec, it looks normal. I don't know why this is, but either way, the exported files are fine.
Colton Davie is offline   Reply With Quote
Old August 15th, 2006, 11:01 AM   #3
In Quicktime Player, you'd need to enable the high quality mode.
Its under the Crtl + J menu somewhere.
Old August 15th, 2006, 01:07 PM   #4
Glenn,
Thank you. That works. High Quality can even be set in preferences, so all files are displayed that way.
Buddy
