Mac green screen software at DVinfo.net
Open DV Discussion
Old August 14th, 2006, 10:00 AM   #1
Since Serious Magic Ultra doesnt work with Mac OS, what would be the best green screen software to use in conjunction with a Avid adrenaline running Mac OS 10.4.7. We have used ZMatte but is there any other software that may be better. Thanks
John M. McCloskey is offline   Reply With Quote
Old August 14th, 2006, 01:31 PM   #2
Combustion 4 may work on Mac
Hello John,
I'm using Combustion 3 on Win OS, but I believe somebody told me you can run it on Mac by installing the "Bootcamp" Apple software. All your Win programs then can be run on Mac. Good Luck!
Cheers,
Christo
Christo Aaron is offline   Reply With Quote
Old August 14th, 2006, 01:50 PM   #3
Shake should come bundled with Primatte, which is a pretty good keyer.
Old August 14th, 2006, 02:41 PM   #4
I use IMovie HD. All you have to do is search on google for, "IMovie green screen plugin" and it should come up. I think you'll have to pay for it tho. Unless you want to use a blue screen. I have a blue screen plugin' that I got for free from the web.
I hope I helped!
~Gabriel~
Gabriel Yeager is offline   Reply With Quote
Old August 14th, 2006, 04:57 PM   #5
If you have motion it comes with primatte keyer as well or you can buy dv matte blast which runs in real time (depending on computer of course ;-) or for a little more dv matte pro, both or these are plugins blast is for motion and pro if for FCP and possible After Effects. As was mentioned before if you have an intel mac you can use boot camp to install XP and then run Ultra from there.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old August 14th, 2006, 05:10 PM   #6
Don't forget, FCP has a built in chroma keyer. I think maybe you are looking for a virtual set builder like Ultra? Not sure what there is to compare to it. Maybe Maya?
Dave Perry Cinematographer LLC
Director of Photography • Editor • Digital Film Production • 540.915.2752 • daveperry.net
Dave Perry is offline   Reply With Quote
Old August 15th, 2006, 08:09 AM   #7
Dave, the original post mentioned using Avid, therefore I guess that cuts Final Cut Pro out. But if you do have Final Cut Studio John, both Motion and Final Cut Pro will give you great results if you spend a bit of time "tweaking".
I would suggest either After Effects or Shake; both will give you fantastic results. Of course, garbage in - garbage out! Although I'm relatively new to it, I prefer Shake over After Effects for keying. But I guess it comes down to personal preference as their both very powerful tools. Both packages have several different plug-ins/tools that can pull keys. You can also purchase 3rd Party Plug-ins for After Effects should you feel the need.
I wouldn't bother trying to run a Windows-based program via bootcamp. It'll just waste time. In the end it will be cheaper just to purchase either Shake or After Effects.
Chris Hocking is offline   Reply
