AVID-Pump up the Volume? at DVinfo.net
Open DV Discussion
Old February 24th, 2003, 01:10 AM   #1
Does anyone know how to raise the input volume with an AVID 3.0 system when hooked up by fire wire to a Canon GL1. The audio tool works fine for audio punch in to raise input volume on CDs through line in, but does nothing when hooked up to the mini DV source and in Record mode and again using the audio tool?
Thanks, Dan O'Bannon
Dan O'Bannon is offline   Reply With Quote
Old February 24th, 2003, 06:20 AM   #2
Not sure about your camera problem, but you shouldn't be running cd's through the line in, just import the file straight from disc.
Richard Alvarez is offline   Reply
