Zooming still images jerk somewhat w/Premiere
I feel like I've tried everything to avoid minor jerky movement while zooming still images in Premiere. It looks like a field issue to me, but I've tried flicker removal, softening the image, etc., etc.
It is minor, but very anoying to me. I would attribute it to the nature of video except it is entirely reasonable to expect a perfect zoom if I were shooting an 8x10 print with my camera and zooming, for example vs. having an electronic file and using the motion control in Premiere. Am I missing something? The photos are scanned, saved to an appropriate size that corresponds to the percentage of zoom I'm using. I'm positive it's not a playback issue...I can do lots of other much more complicated effects without a hitch. Thanks.
John Paulsel Highpoint Productions "I'd do it for free but I don't!" |
RED Code Chef
If it is a still or scan I don't understand why you are looking at
interlacing: it is not interlaced. Make sure Premiere understands that it is a progressive source. What resolution is your picture, what file type?
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
I've tried a number of file types, but usually use .jpg's. For full frame, "non-zoomed" use, 720 x 540. If I know I'm going to do some sort of move, I increase the size in proportion to the percentage of enlargement I'll use.
Full frame still images look great. Moving smaller still images seem fine (but could be less noticeabe because they are smaller?) I've tried the "flicker removal" only because the probem seems to have the same characteristics as "fine line" flicker as the image enlarges. You lost me on the progressive source comment. Thanks for your help.
What I've experienced isn't exactly jerkiness, it is a sort of artifacting due to jaggies in diagonal lines on moving stills. Looks somewhere between a minor jerkiness and a sort of shimmering.
I've had the same problem in Premiere and Vegas. I have just chalked it up to DV and 4:1:1 color space. The images may be higher resolution stills but at some point they have to be converted by the software to NTSC DV, with all the limitations that that implies. I may be all wong here. (I often am.) |
#5 |
Rick, I think we're on the same page. What doesn't make sense to me is that I can do a perfect slow zoom using the camera and an 8x10 or larger print, but it looks imperfect when doing it as a digital "effect".
Watching "Biography", they often use slow zooms and pans on still images and it's flawless. Judging by the complexity of the moves, I'm sure it's done digitally, unless they have a motorized camera stand and compound (ie. Forox, Oxberry).
#6 |
RED Code Chef
Perhaps Premiere is not doing such a good job? Maybe try out
a demo of another NLE to see what kind of results they get? (the best one to try is probably Vegas 4.0.
#7 |
I used to have this problem with Premiere, until I found a way around it. This is what I do to get smooth zooms and pans on stills in Premiere.
First, I don't use Motion, but instead the Image Pan transform. Motion loses resolution on zooms, Image Pan does not. Next, using Photoshop or another paint program, I resize (sometimes called resample) the still to the maximum size Premiere will accept, i.e. a square image would be 4,000 x 4,000 pixels, a rectangular image would have its longest dimension set to 4,000 pixels. Finally, I save the image as an uncompressed TIFF file, never as JPG or BMP. (In addition to providing a high-quality image without compression artifacts, the TIFF format can maintain an alpha channel, which I tend to use a lot for titling sequences and major transitions). Using this technique, I can zoom in on a still image by 400-500% without blockiness or motion artifacts (obviously, though, resizing won't add detail that wasn't there to begin with -- I try to scan images to the appropriate size whenever possible). My zooms and pans are liquid smooth and artifact free. The only downside, it takes Premiere quite some time to handle images this large -- display of the timeline can slow down and, of course, if rendering is necessary, it takes much longer to process these large images than it would if they were 720 x 480. |
#8 |
Thanks, Paul. I'm going to try it right now.
#9 |
Paul, you are the man!
I tried resaving an existing fairly large .jpg to a .tif and using Image Pan...it was much better but still a little ragged at the first part of the clip, then smoothed out considerably. Then, I rescanned the image at 4000 pixels wide and saved it as a .tif with no compression. Outstanding results! It takes 5 times longer to render vs. using "Motion", but the result is 500 times better...very flluid. Plus as you mentioned, there is no loss of picture resolution. What resolution do you use in Photoshop? I kept my test at 300 pixels/inch . Would reducing it to say 100 be counter productive? Just trying to make it process a little faster. I'm using grayscale images...color ones would slow up the works even more. My thanks to you and this forum.
#10 | |
#11 |
Paul,
Thanks. I may try reducing the resolution while keeping the pixel size as you suggested simply to reduce the file size. Not sure if it would effect the rendering time or refresh rate on the time line or not. Once again, thanks for the great info. I thought I'd sampled every video effect Premiere had, but I missed this one.
#12 | |
If you're resizing (or scanning) everything to a maximum 4,000 pixel resolution, the file size won't be effected, since each picture will have the same number of pixels, i.e. 4,000 x 4,000 or 16M, regardless of resolution. |
#13 |
I played around with this a little today. Using uncompressed images helps a lot. Seems obvious now. JPG is a compressed medium, as is DV. No need to combine the two. Thanks for the tip, Paul.
The other thing that I found that worked well was deinterlacing the final file. I tried with both Canopus "old movie filter" using the "blend" option and Vegas, also using the "blend" option. I used a photo that was handy and it turned out to be a tough one. The photo was my son on a skiing trip. In the background are trees covered with snow, resulting in a complex pattern of light and dark. The foreground looked fine. The background however had a pronounced shimmering effect as I zoomed in or out. This was worst witha jpg file. It improved but did not go away with a targa file. Once I deinterlaced, it was a reasonably smooth zoom. Of the two deinterlacing methods, the Canopus was slightly better than the Vegas. For what it is worth. |
