1.7x Tele Adapter Sony VCL-HG1758 - Who has used one of these? Good? Bad/indifferent? at DVinfo.net
Open DV Discussion
Old June 21st, 2006, 11:05 AM   #1
Old Boot
I'm considering using it on my XM2. Anybody had any experience of this adapter?
TIA,
Grazie
Old June 21st, 2006, 12:50 PM   #2
I have this extender, and have used it on my VX2000. It does vignette at mid range back to wide. Some darks corners disappearing as zooming continues and depending on aperature.
The image quality is pretty decent, though I haven't tested lines of resolution or anything like that. CA seems to be under control. I've even used it with a step up ring on my FX1, and the have decent results with the HDV images.
Chris J. Barcellos
Old June 21st, 2006, 03:12 PM   #3
Old Boot
Chris, thank you.
What is the diameter of the "big-end"? I have a matte box with a 80mm clamp ring.
TIA,
Grazie
Old June 21st, 2006, 03:59 PM   #4
I'll have to check out this evening. Am at office right now.
Chris J. Barcellos
Old June 21st, 2006, 04:01 PM   #5
Old Boot
Excellent! Thank you .. . G
Old June 21st, 2006, 07:14 PM   #6
Graham:
Looks a bit bigger than that. The metal shade in front is around 92 mm, and if you mounted on the rubber ring its up to 94 mm..
Chris J. Barcellos
Old June 21st, 2006, 11:36 PM   #7
Old Boot
Originally Posted by Chris Barcellos
Graham:
Thank you Chris. What rubber ring? . . . Grazie
Old June 22nd, 2006, 11:09 AM   #8
Its like a rubber bumper material recessed from front edge of lens going all the way aroung the lens. Probably to protect in a drop situation. Nothing major, just adds to the circumfrence a bit if you are attaching your ring there.
Chris J. Barcellos
Old June 22nd, 2006, 03:13 PM   #9
Old Boot
Chris? Do you have any "stills" of what this 1.7 can do? If you don't, don't worry.
Grazie
Old June 22nd, 2006, 03:16 PM   #10
Want them from my VX2000 (actual stills from camera ) or screen grabs from FX1 HDV ? I'll put some together tonight.
Chris J. Barcellos
Old June 22nd, 2006, 07:31 PM   #11
Grazie
Here are two photos to compare shot with VX 2000:
http://www.makeyourfilm.net/downloads/withextender.jpg
http://www.makeyourfilm.net/downloads/notextender.jpg
Chris J. Barcellos
Old June 22nd, 2006, 08:02 PM   #12
Frame Grabs from FX1
These are the frames I grapped from my FX1, one with the extender, one without:
http://www.makeyourfilm.net/downloads/normal.jpg
http://www.makeyourfilm.net/downloads/extender.jpg
Chris J. Barcellos
Old June 23rd, 2006, 07:55 AM   #13
Old Boot
Chris, thank you for taking the trouble. Grazie
Old June 23rd, 2006, 02:33 PM   #14
Graham:
Any conclusion after looking at the frames ??
Chris J. Barcellos
Old June 23rd, 2006, 03:27 PM   #15
Does this mean I don't have to pay $850 for the Century 1.6x for my FX1?
What about the Century 2x-58mm for the PD-170? How does that work with the FX1? Anyone try it? Maybe I should post a new thread.
Thanks.
Stephen Claus is offline   Reply
