My first locker room shot! at DVinfo.net
Open DV Discussion
Old May 25th, 2006, 10:25 AM   #1
What you see is a Set of lockers, and a camera pan across. Everything you see was graphically produced by me. A mother gave me newspaper articles from the press gazette, in Photoshop i put them on the lockers. The lockers you see are not even real. I made one, duplicated them then made minor changes to each locker. I created the tape used to put them on the lockers, the curl in the pages, made them look as if they were ripped from the newspaper, the rust on the lockers, the spray paint, you name it. Took me a little time but it was fun and it turned out very well. I'd like you guys to see it. Just give a little feedback if you like or not, or am I just getting too excited over this stuff. If so, sorry, I'm easily excited.
http://www.bigeyedeamedia.com/LockerPan.wmv
Thanks again
David Nelson - www.gbdvd.com
David Nelson is offline   Reply With Quote
Old May 25th, 2006, 10:39 AM   #2
Very realistic. I was not happy with red paint (blood?) on the locker. It looked like it was floating a bit instead of actually on the locker. All in all, a great job.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old May 25th, 2006, 10:42 AM   #3
whooops you thought that was blood, it was supposed to be rust. I'll take a RE-Look at that one. Thanks!
Old May 25th, 2006, 11:31 AM   #4
David,
Very nice looking, but it went so fast it was disorienting. I second the notion that the red looked like blood. Certainly not like rust. It needs to be quite a bit deeper/darker and maybe a bit more towards orange.
Josh
Owner/Operator, 727 Records
Co-Founder, Matter of Chance Productions
Blogger, Try Avoidance
Joshua Provost is offline   Reply With Quote
Old May 25th, 2006, 12:46 PM   #5
Images: 1
Take a look at the last shot. Rust wouldn't be covering the newspaper article whereas blood might have. The rust should have more brown tinge to it. You also need to think about rust formaton. If it is the result of water dripping from above and running down the lockers, it would need to be rust streaks. If it formed because the protective paint on the lockers was compromised from things banging into them, then it will be more random size and location.
And yes, slow the action down please, it is supposed to be a reflective moment by showing all those newspaper clippings of past headlines.
Pretty realistic looking though!
-gb-
Old May 26th, 2006, 12:03 PM   #6
I'll try to remove repair the blood/rust. Slowing it down will be a task but I'll do it. THanks!
Old May 26th, 2006, 01:40 PM   #7
David...
Sure looks real. Nice work! Was this done freehand or with the aid of 3D software? If it's freehand, you have a very, very good eye for reflections, highlights and shadows.
Some suggestions:
-- the newspaper clippings are very clean and straight. Newsprint taped to a wall would normally start to curl from the point of suspension. Also, you might want to give each one a slightly yellowish tinge. Doesn't take long for newsprint to start to discolor. Maybe a slightly rougher edge, indicating they were cut with a pair of scissors, or even torn out with the aid of a ruler.
-- Rust usually forms where paint has weak points: corners, edges. Maybe near the vents and seams of the locker.
-- For those anal enough to notice, all the padlocks are set to the same number on the combination dial.
-- Maybe add a few dents to a couple of the locker doors? Especially to the vents which are more vulnerable to damage.
Impressive artwork.
Dean Sensui
Dean Sensui is offline   Reply
