Looking for Variable Neutral Density filters?
I am looking for Variable Neutral density filters. These are things where you can select the density your want, even on the fly.
I am interested in what variety is out there, anybody know? Thanks Wayne. |
I've never used them, but I've heard that the ones sold here are really good:
http://www.singh-ray.com/varind.html |
You can make one yourself from a pair of polarizing filters. When they are in congruence, they'll have twice their filter factor, and a 90-degree twist will block all light. Downside is not knowing the exact reduction at any point between, but you could guestimate it and use a metallic Sharpie to mark the points of min and max and in-between.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -- Benjamin Franklin, 1759 |
Thanks for the replies guys. Yes, I remember it when I had a look at the one above (it even says that it will work with anything but polarisers). I am still interested in seeing what other solutions are available, as even the best polarisers I've seen kill a lot of light. I would like to find something that is almost clear, so it can be left on the camera in all conditions, as I walk around.
I've had a few ideas in times past on how to make one, but they are complex, or sloppy, a good manufactured product would be nice. |
#5 |
If you're looking for something that doesn't kill light, neutral density filters aren't what you need. If you simply want to protect the lens, get a UV filter but remember there are situations you'll need to remove it or it will affect your image which is why I personally don't like them.
#6 |
I still want a ND like reduction, but something you can turn down to nearly 0 ND, so I can walk into a low light situation without having to ever remove it. Once you get below 50% light loss, polarisers cost heaps too. I think the one above is two 50% polarisers because of the two stop loss minimum. I think I might have a solution for a polariser that can have light loss of much less than 50% hopefully down to less than 10%, but unfortunately I haven't got the ability or equipment to design it. It was a solution to another problem I was thinking of today.
Anyway, so are polarisers the only solution out there? Thanks Wayne. |
