What FOV (Field of View) does my lens have? at DVinfo.net
Open DV Discussion
Old January 26th, 2003, 09:12 AM   #1
Dreadman
Posts: n/a
Hi, is there anyone out there who can tell me what FOV (field of view) my lens has? Without zooming.
Or how to calculate it?
Here is the type of lens I'm talking about:
FUJINON S19X6.5BRM-24
6.5mm - 123mm
Don't know the size of the camera's CCD's, it has either 2/3 CCD's or 1/3 CCD's.
It's a Panasonic DVC Pro 25. I can't check the exact specs of the camera right now as at the moment I haven't got the camera or manuals within reach.
Help will be much appreciated.
C-ya.
Old January 26th, 2003, 11:24 AM   #2
Warden
I can tell you a little bit about it.
S = 1/2 chip format
19 = is 19X or Zoom ratio
6.5 = minimum focal length, maximum can be derived by multiplying 6.5 by 19 = 123.5mm
In 35mm film terms, this lens on a 1/2 chip camera, is the rough equivalent of 36mm to 692mm. This equates to roughly 53 degree angle of view at 6.5mm to 2.5 degree at 123.5mm.
It is probably E R M which means E is a built in 2X extender, RM is manual focus, servo zoom.
Jeff Donald
Carpe Diem
Old January 26th, 2003, 12:58 PM   #3
Dreadman
Posts: n/a
Thanks for your reply! Got some really usefull info from that.
I've done some searching on the web prior to reading your reply and came accross this link http://www.csgnetwork.com/objsizecalc.html
But when I calculate my FOV over there is states I should have a FOV of 76.23 degrees, which I'm sure is totally wrong.
Your 53 degrees sounds a lot more reliable.
BTW: How do you make an estimate of the equivalents between 1/2 CCD Cams and 35mm cams. (Is it just by multiplying with +/- 5.5?)
C-ya.
Old January 29th, 2003, 05:06 PM   #4
Warden
The 53 degree angle of view is from some old Fujinon literature I have. The conversion factor for various chip sizes compared to film can be found here. I should note that the 35mm listed as 1X is 35mm still film, not motion picture film. Charles provided some figures for me and I'll update the list in a day or so.
Jeff Donald
Carpe Diem
