Can i use NTSC camera in PAL country? at DVinfo.net
Open DV Discussion
Old March 13th, 2006, 07:40 PM   #1
For distribution of documentary movie in Russia (PAL/Secam) and USA (NTSC), should i use 50i or 60i as a master?
russian in new york | graphic designer | filmmaker | http://www.designkarma.com | Sony HDR-HC1
Timofei Youriev is offline   Reply With Quote
Old March 14th, 2006, 11:43 AM   #2
From my travels, I've noticed that PAL countries can see NTSC tapes/dvd/television easily out of the box on their TVs.
The reverse is not true.
I would go with 60i NTSC.
But what do I know?
$.02
Chris Luker is offline   Reply With Quote
Old March 14th, 2006, 11:49 AM   #3
if support is a DVD, i do not know an european having purchased a DVD player and a TV set without being sure he will be able to play Zone 1 (USA) DVD
Old March 14th, 2006, 12:46 PM   #4
if you are going to sell/broadcast it you should convert it to PAL....
i use Atlantis for converting job, but it aint perfect...sometimes picture looks a little choppy...
i have NTSC camera and i my movies are broadcastet on our tv channels after converting to pal
Andzei Matsukevits is offline   Reply With Quote
Old March 14th, 2006, 09:07 PM   #5
Thank you everyone!
Andrey, did you ever tried converting from HDV NTCS camera down to regular tv resolution PAL?
Old March 15th, 2006, 10:11 PM   #6
Keep in mind... as a general rule of thumb, PAL to NTSC transfers usually look a little nicer than NTSC to PAL when they are done on consumer or pro-sumer level equipment.
Randy
Randy Rogers is offline   Reply
