Delay live video by about 5 minutes? - Page 2 at DVinfo.net
Open DV Discussion
Old February 14th, 2006, 08:21 AM   #16
Originally Posted by Brian Farris
Well, we really need to use coax for the connection from the camera to the computer, since the camera will normally be ~100ft from the plasma screen. I dunno if S-video has that capability/low cost.
well its a TV tuner, so of course its going to have a coax input. Although you'll need to make sure your source can set the video to work on channel 3 or 4, like a regular tv.
Jay Cowley is offline   Reply With Quote
Old February 14th, 2006, 08:50 AM   #17
All HDD home recorders can, like Richard already wrote, playback footage while recording that same footage. So, just start playback 5 minutes after you started recording and you are set. A 160GB unit costs less than $500 and will allow good quality delayed video for several tens of hours before the HDD get full.
Andre De Clercq is offline   Reply With Quote
Old March 17th, 2006, 11:44 PM   #18
I know there are tons of options but the main problem is finding a device that has a coaxial input which does not require to be tuned to a certain channel, since the XL2 can not output to a certain channel.
I need something that has a coaxial connection that treats it as a plain ole signal.
Brian Farris is offline   Reply With Quote
Old March 18th, 2006, 03:20 AM   #19
Put an VCR in between. XL2>VCR (short video cable), VCR (antenna out)> long coax> DVD recorder antenna in.
Old March 19th, 2006, 11:12 PM   #20
That would probably work, but is there anything simpler/smaller than a vcr that will acomplish this?
Old March 25th, 2006, 06:48 PM   #21
This may be a little late to be of help but I saw this thread last month and then the other day I stumbled across the sony dsr-1000. It will allows playback of any segment while still recording. Good luck, Jason.
Jason Varner is offline   Reply
