connecting it all at DVinfo.net
Open DV Discussion
Old February 11th, 2006, 07:58 AM   #1
connecting it all
Not sure where to put this. Did a search but didnt come up with much
The more equipment i get the more annoying it is to work with it
Cant afford to spend 10K on a video matrix but i guess there has to be something i can get
My biggest issue is that i have multiple VCR's, DVD recorders, cameras and one thing i always have to do is to watch it on a screen so one thing would be to be able to hook up that monitor to all devices via standar video cables or if possible a mix of video or s-video as most of these devices also have s-video
Most of the recording is done via firewire but of course some of them do not have firewire but rather have video or s video in/out
Looking for any tips to solve issue 1 with the monitor or both things (viewing / recording). As i mentioned earlier i can only spend so much on this but am happy to hear any suggestions
Michael Salzlechner
Michael Salzlechner is offline   Reply With Quote
Old February 12th, 2006, 06:36 AM   #2
RED Code Chef
I personally use an AV receiver for that job. It routes all different kind of input
signals (mine doesn't do firewire / DVI / HDVI though, but AV receivers do exist
for at least the latter two) and outputting it as composite / svideo or even
digital form (depending on the kind of receiver). Added bonus (for me) is that
it also switches audio and decodes dolby digital / dts
Rob Lohman, visuar@iname.com
Old February 12th, 2006, 08:22 AM   #3
Michael,
I use a Kramer 8x8 matrix switcher to solve the problem. You should be able to find one for under $1K which isn't cheap but the it sure is great to leave all your gear connected and be able to connect any piece to any other piece. Can even be controlled via the RS-232 jack from your edit computer.
http://www.kramerelectronics.com/ind...em.asp?pic=315
Rob Wilson is offline   Reply With Quote
Old February 13th, 2006, 06:52 PM   #4
Michael,
Just came across this on ebay. It's similar to the Kramer I use in function.
http://cgi.ebay.com/Knox-RS8x8-8x8-R...QQcmdZViewItem
The price is right (at least right now).
Old February 13th, 2006, 06:59 PM   #5
thanks will check that out
Michael Salzlechner
