Windows Movie Maker - capture plays back too fast! at DVinfo.net
Open DV Discussion
Old February 4th, 2006, 04:39 PM   #1
I am trying to capture to Windows Movie Maker from a Sony TRV230 camcorder via Firewire (under XP SP2). The capture seems to work fine (any video mode), but when I play back the clip it is accelerated (audio and video both) - about 1.5 times normal speed. MS warns that having Intervideo's WinDVD on the same computer can cause this, so I deinstalled it and even manually removed from the registry a straggler reference to its filter... but even after a reboot the problem persists. I have tried all options in the WMM menus. The only filters showing now are two Nero burner filters and I have unchecked both.
What's wrong? This is pretty frustrating. I am about to put another dart in my Bill Gates dartboard. Come to think of it, that can actually be quite satisfying...but I still need to solve this dumb problem. Any guru hints?
Edward Hamlin is offline   Reply With Quote
Old February 5th, 2006, 01:05 PM   #2
does it play fine in Media player? If so, I would try reinstalling Movie maker.
If reinstalling it doesn't work, perhaps trying a different program - Movie maker is fine for begginers, but if you want to get more into editing and have more control, you'll eventually want to get a higher end program.
Andrew Khalil is offline   Reply
