BetaSP and big lens = good DOF at DVinfo.net
Open DV Discussion
Old November 24th, 2005, 11:29 PM   #1
I have a BVW 300AP which has 3 2/3" CCDs.
I also have an 82mm Canon ProTV Zoom Lens (15x i think)
Does the large sensors coupled with the large lens help to give me more of a film look (regarding DOF) than many other setups?
I suppose if i closed the iris i would have more of a film look...
Could someone just clarify this for me?>
Thanks.
Davey Magill is offline   Reply With Quote
Old November 25th, 2005, 12:03 AM   #2
Nearly correct apart from the fact that you will need your iris open for a shallower DOP (the look of film) which I think you are wanting. The 2/3" imaging plane will be good for a relatively shallow DOP if your iris is fully open ie. f.2.8 or less. Large lenses can help so if you are struggling for super shallow even with 2/3" CCD's then you have yourself covered.
Ainslie Davies - www.dualityproductions.com
Ainslie Davies is offline   Reply
