DVCPro to PC?
Found a really good deal on a Panasonic DVCPro 50. - https://cinequipt.com/products/panas...-50-camcorder/ . BUT - I'm not seeing ANY easy / inexpensive way to get DVCPro footage to my PC. Is there such a thing?
Thanks :) |
Re: DVCPro to PC?
If and this is a big IF the camera has the optional SDI board in it, this is the board
https://www.bhphotovideo.com/c/produ...2855/KBID/3801 Then the goal of getting the images out of the camera becomes a lot easier. What I have done with cameras of this vintage that are tape-based is to play out the tape from the camera through the SDI port and then capture that SDI stream into an Atomos Ninja Blade, Ninja V or a BM Video Assist recorder via their SDI inputs. Capturing the stream as a Prores or Avid codec file. Then it's just a matter of importing your file from the SSD or HDD or SD card of the Atomos/Video Assist and away you go. If you want to shoot straight into one of the Atomos/Video Assist recorders you can do that directly from the camera. You have to run a cassette in the camera with the camera time code set to Record Run to trigger the recorders. With the recorders set to trigger via the incoming embedded SDI time code, the recorders will stop/start every time you stop/start the record on the AJD. Without no SDI output on the camera then you do really need a DVC Pro 50 deck with SDI out to keep life simple. Chris Young |
Re: DVCPro to PC?
Thanks for the info.. Dang. So I'm looking at another $500+ easy it sounds like, on top of the camera. At that point, not sure it's worth it? Looking at a deal for maybe $600 for 2 cameras, selling one might be tough, but would help recoup SOME costs, but then $500 for the equipment IF one of the cameras has that board. So probably a pass on the camera. :(
Oh, is there a way to tell if the camera has that board? Thanks :) |
Re: DVCPro to PC?
From memory, there is a setting in the menu for SDI output if the SDI board is fitted. Don't ask me which menu though. It was a long time ago and the old brain is fading!
ChrisYoung |
#5 |
Re: DVCPro to PC?
Dang. Ok, thanks. So sounds like as much as I'd love this camera, I'll pass. Sounds like it'll be impossible to get footage from it without spending a fortune.
#6 |
Re: DVCPro to PC?
Would something like this not work.
A little knowledge goes a long way but not long enough. |
#7 |
Re: DVCPro to PC?
These type of threads have come up before. I get the appeal of buying old pro gear at a fraction of the price but these things are less appealing once you dig deeper into the associated costs and work flow you’d need to adopt. These cameras would also need big heavy expensive tripods. Capturing tapes suck. Saving money isn’t a good reason to get these cameras
#8 | |
Re: DVCPro to PC?
#9 |
Re: DVCPro to PC?
News is often shot in HD these days. The nice thing about the traditional ENG stye cameras are the zoom lenses, often with a x 2 range extenders and you can hold them for long times on your shoulder.
However, today, I would try to get something like a used Sony PMW 200 for stringing. They have a decent zoom range for those stories where the roads are blocked off. These days speed is everything on 24 hour news, so you can get your file(s) to the news provider extremely quickly with these later cameras. |
