#241 |
Re: Do I tend to overthink things in filmmaking?
It clicked one day in a theatre. I use purple poly strops for dangling heavy items from steel beams and realised they’re ideal for going around the usual pillars we get in our old churches with lots of these supporting the arches and other overhead features. They usually have a proper top on which the timber or masonry sits and these strips can go around and be choked easily then with a normal shackle you can send 3mm cable across to the other side. First time I cut the cable and used the normal cable clamps but later I thread the 3mm cable through the shackle and drop it down and hang some sand bags on it at ground level. This easily puts tension on and the mic cables are taped to the catenary. The soft strops leave no marks even on old brickwork or plaster.
#242 |
you should post pictures, because when you say strop I'm imagining I'm at the barbershop getting a shave
Maybe you have different architecture. Around here I either get residential smooth walls and ceiling with no beams or modern offices with large open spaces and nothing structural to latch on to. It would seem to me a few c-stands would do what's needed quicker and more safely. But I'm still curious. Last edited by Pete Cofrancesco; October 1st, 2020 at 12:26 PM. |
#243 |
Paul, that's a clever idea to use what I would call a sling (a loop of flat woven polyester) around the supporting pillars in a church. Unfortunately the churches I'm thinking of don't have free-standing pillars in front of the nave; the transcept and chancel are one big open area). No pillars over the chancel or choir (those supports are part of the wall), so not a solution for micing the choir (or preachers).
However it would be a good solution for micing the pipe organ, assuming there are pillars at a distance where there's a good direct / reverberant mix. I presume you do need a ladder to attach the slings to the pillars. So for recording in an unoccupied church, light stands might be simpler. But for recording in an occupied space, and keeping the mics out of the way, that's a great technique. Yes, a few photos would be nice, if you have any handy. |
#244 | |
also known as Ryan Wray
I can bring in actors from other cities too, if I have to. I just need more options I think. |
#245 |
Slash Rules!
you need to find out their specific reason for screwing you. if you can remember any of them from past incidents, tells us and we might be able to tell you if it sounds like a bs excuse to get rid of you
#246 |
I really cannot remember the specific excuse. It had something to do with the business and his wife, but I do not remember the specifics at all. One time someone I know let me use their house but then I find out on the shoot day, the power had been cut because they were being evicted, they had found out, so that's one I remember.
#247 |
Slash Rules!
Uh, WOW.
did you try to verify that or just take them at their word? |
#248 |
Ryan and the amateur movie "business". He has a long road ahead of him. Lesson 589,999 even free things have a price. l can only imagine all things that go over his head. If he only knew what he didn't know. Although they say ignorance is bliss.
#249 |
Well I only had a limited amount of time to shoot before the power went out completely, so I figured I should use that time to shoot, rather than verify if it's true, thus if it is, I would have spent that time on investigating, and keeping the cast and crew waiting, instead of shooting.
#250 |
Slash Rules!
Oh I see. I thought you meant the location owner/renter cancelled on you completely with that as the excuse. So did you witness the power actually going out then?
#251 |
Oh sorry for the confusion. Yes the owner did cancel in the sense that we could only use the location for a much shorter shoot time. But the power did go out at the time that he said it was going to, yes.
#252 |
Slash Rules!
I guess that could be legit. It’d take a pretty dedicated jerk to flip the switch on his fuse box to fake a power outage. Still, “power outage due to eviction” is a new one for me.
#253 |
Ryan, I'm curious. Was the power outage in someone's home, or in a place of business?
#254 |
I wonder how he never tires of it. Whatever the reason, it sounds like a scrappy existence. Every thing, from borrowed equipment, volunteer cast/crew, free locations... He's like a factory churning out endless questions and problems in need of constant help and favors.
#255 |
Slash Rules!
I agree but at the same time I'm kinda jealous. Wouldn't it be awesome to run into nothing but problems and criticisms, and never have your fire burn out? Most of us should be so lucky.
