Question about shooting news documentary style in this case. - Page 2 at DVinfo.net
Open DV Discussion
Old June 19th, 2020, 09:28 AM   #16
also known as Ryan Wray
Re: Question about shooting news documentary style in this case.
Oh okay thanks. What about skipping ahead in someone's speech? I've noticed they used flashes of white to do that. I can just cut ahead, but then that's jump cutting, but maybe jump cutting on the news is okay, even though you never see it?
Ryan Elder is offline   Reply With Quote
Old June 19th, 2020, 10:54 AM   #17
News edits frequently just stuff together clips edited for the audio, and sometimes they'll slap all kinds of transitions on them, often with a whoosh or other SFX. If you watch just one or two hours of a con sinuous news channel, you'll see edits done for speed, and if the cut jolts too much, they simply soften it with something suitable.
Old June 19th, 2020, 11:16 AM   #18
Oh okay thanks.
I also noticed this type of transition at 0:49 into the clip:
The do a fade to white and back to avoid jump cutting. I could do that or just have jump cuts intentionally for style.
Old June 19th, 2020, 11:48 AM   #19
There are no rules, it really depends on what you're doing and on each news station's requirements. Some insist that you show that speeches have been edited,, others allow cutaways in order to avoid jump cuts.
I'm not sure why you're asking these things. Your editor will be the person creating these news bulletins (even though it's you) and the style may have changed in the meantime. They' used to cut to black, so these the things go in and out of fashion. This one simulates a flash frame, which what happens on film cameras when they're stopped filming and a couple of frames get over exposed before the reflex mirror on the shutter is lined up.
Use the transition effect that best suits your story and the action, you don't need to set it in stone for the moment. .
Old June 19th, 2020, 02:03 PM   #20
Oh okay thanks. It's just that I was planning the shoot with the edit in mind, because I thought that would be better, rather than not shooting for the edit.
Old June 19th, 2020, 03:57 PM   #21
It doesn't make any difference during the shoot if you plan to use a jump cut, a flash frame, a cut to black or everything spins like one of those old newspaper effects.
Old June 19th, 2020, 05:49 PM   #22
The only thing you need to make sure when you film is that you leave few extra seconds at the start and end for the transitions. The Weinstein clip has bunch of common transitions mainly fade to color either white or black. This is really basic stuff.
Old June 20th, 2020, 12:02 AM   #23
Yes, remember your overlaps.
Old June 27th, 2020, 12:45 PM   #24
Ryan has been missing for a while and this news jump cut topic has appeared on the DVX forum, posted by JimS2 - who oddly, starts every post with "Oh, OK, Thanks......" I'd bet Ryans' started anew over there.
Zooming vs. speedramping, which looks better? - Page 3
is a typical Ryan topic. Things might be quieter here if he's jumped ship.
Old June 27th, 2020, 04:52 PM   #25
I kinda miss him but maybe if JimS2 spends most of his time on dvx forum might not be such a bad thing. Ryan errr I mean Jim could use a fresh start
Old June 28th, 2020, 12:55 AM   #26
It would seem that he's getting the same range of answers to the same range of questions.
Old June 28th, 2020, 08:50 AM   #27
Trouble is, he's not moved forward - he's doing the cheap lens crash zoom thing again, the topic about his script and the policeman and the current news cuts.
I did kind of think we'd been helping and guiding him OK, clearly he still hasn't got the answers he wants.
Old June 28th, 2020, 09:16 AM   #28
What you want and what you can get can be entirely different things, especially if you don't have or are unwilling to spend the money required. Paraphrasing John Boorman's book title, it's about turning money into light.
Unfortunately, he keeps on painting himself into a corner without noticing the ground floor window beside him.
Old June 28th, 2020, 03:47 PM   #29
DVXuser.com -- The online community for filmmaking
They spotted that Ryan was previously Ironpony, and they mentioned he'd posted the same things before.
Old June 28th, 2020, 04:51 PM   #30
I had a quick search and Ironpony seems to have the same issues that Ryan has in hearing things and (apparently) not really understanding. Plus the suggestion (in 2013) that he has done this on a number of other forum boards.
There's a definite pattern that been going on for years and this film (seemingly) hasn't yet gotten to a festival.
Brian Drysdale is offline   Reply
