What camera would be best for me when it comes to color grading? - Page 31 at DVinfo.net
Open DV Discussion
Old March 8th, 2020, 11:41 AM   #451
also known as Ryan Wray
Re: What camera would be best for me when it comes to color grading?
Oh okay, well so far for this story situation, I was going to have the long lens panning shot, be mostly a mastershot, I would cut back to whenever I please.
Then I was going to do all these other shots closer up to the action. But I could have the a car tracking shot as a master shot, if that's better.
Ryan Elder is offline   Reply With Quote
Old March 8th, 2020, 11:43 AM   #452
Originally Posted by Ryan Elder View Post
Well I wanted to do a test there but it costs a lot to shoot there, and that would be an extra day of costs to do a test. I tried just going there to do the test without it being a shoot day, and just see if I could do it, but they would not let me. That's why I didn't choose there. But I thought that the park test, would also suffice for the outdoor chase as far as tests go.
Why can't you go to the garage at an off peak time to a level no one is on and do some unobtrusive tests hand held with your camera? Or find a similar garage.
Old March 8th, 2020, 11:44 AM   #453
I tried going at 10 at night when no one was around and two security guards came out the door and asked me to leave before I could even set up the tripod.
Old March 8th, 2020, 11:51 AM   #454
Perhaps the concept of a master shot is holding you back with a chase scene.
Old March 8th, 2020, 12:00 PM   #455
Oh well I felt the other shots would be easier, it's just the master I was asking about since I would want more DOF in it theoretically since it's a longer focal length. However, would it be better if I had a tracking car shot as the master shot instead?
Old March 8th, 2020, 12:07 PM   #456
What part of unobtrusive don't you understand? Find another garage that has many floors, be mindful of their security cameras and do hand held tests. Or shoot from in the car. You give up so easy.
Old March 8th, 2020, 12:11 PM   #457
But I can't do a handheld test on a telephoto though, for a telephoto panning shot. If I am trying to do the same telephoto shot panning shot, I need a tripod. If I do a car tracking shot as a test, then I need to drive around with a car while shooting. These are not handheld shots we are talking about here.
Old March 8th, 2020, 12:13 PM   #458
Use your storyboard to plan shorts, have overlaps. Most of the time master shots never get used, so don't waste too much time thinking about it.
Old March 8th, 2020, 12:14 PM   #459
Well it's just in the past when I didn't use a master, I felt I need more coverage later, so going by my own experience, masters are good to have. What do you mean by 'overlaps' in this context?
Old March 8th, 2020, 12:52 PM   #460
Overlap the action between the shots, so that you've got a choice of cutting points.
If all the action within the scene isn't seen in the shot, it's probably not a master shot.
Having the storyboard means that you won't leave out shots. There probably isn't a master shot in the Psycho shower scene because elements (if not the whole scene - still up for debate) were storyboarded by Saul Bass.
Old March 8th, 2020, 12:52 PM   #461
Your film course really was rubbish Ryan. They don't seem to have covered any of the craft, just the art - and that in a very haphazard way. Have you noticed that Pete, Brian and myself often do things differently through choice, but easily understand each other, and what they are trying to tell you - but you don't?
Overlaps, in the context used above is perfectly straightforward and obvious. If you can't get it - then our help is pointless.
And yes - you give up so easily I'm amazed you even get anything shot.
Old March 8th, 2020, 01:05 PM   #462
There are many purposes of a test. Can you shoot with existing light? Is the lens too slow or not enough dof. The point is not to do a perfect pan it's to determine whether the shot viable at that location. You might even discover that you don't want a telephoto because there isn't enough room. That the whole panning idea doesn't work in this location! If you must setup a tripod do it quickly not in view of security or surveillance cameras, inside the car, behind a pillar...
You turn everything on it's head. You've predetermined this panning shot is necessary when it's probably not.
Old March 8th, 2020, 01:18 PM   #463
Well I managed to get a bit of footage before I was kicked out with the telephoto lens. I think there is enough room, the pans just won't be really long.
I also did some handheld tests. Without lighting, I have and the existing light, I would have to shoot at ISO 800, shutter 1/50, and the aperture open to f2.2.
But with a better camera, perhaps I could close that aperture more for the action, and not have as much noise, but also more lights?
Old March 8th, 2020, 01:43 PM   #464
Again if you already have done the test and have determined that is what you want then why are you asking us?
Old March 8th, 2020, 01:49 PM   #465
How much lighting will you need for a car park? If you got chucked out with a small tripod, how will you get access for a day to set up lights? Not really viable as a guerrilla shoot.
