Is true that most film festivals will only accept two aspect ratios? - Page 2 at DVinfo.net
Open DV Discussion
Old April 19th, 2019, 01:39 PM   #16
also known as Ryan Wray
Re: Is true that most film festivals will only accept two aspect ratios?
Okay thanks. Well I could do the 2.20:1 since that seems to be the best aspect ratio for my taste, if it's no big deal for projectionists, but if it's risky, and could be the reason why a film festival were to turn me down, then I could play it safe and shoot in 2.39:1 if that's best.
Ryan Elder is offline   Reply With Quote
Old April 20th, 2019, 02:07 AM   #17
Using 2K, for Scope (2.39:1) presentation 2048×858 pixels of the imager is used, so I would keep the 858 pixels for your vertical resolution and let your horizontals have pillars on either side, You won't fill the screen width, but should work even if the projectionist has little technical knowledge.
It will also work in theatres that open the screen edges in the traditional manner for scope films, so that the whole screen is wider. Changing the vertical resolution in this case could result in the lower and upper parts of the image of your film also projecting on the back of the audience heads and the ceiling.
Old April 20th, 2019, 03:59 AM   #18
Oh okay, I thought it would be better to have a 1.85:1 image, with black bars on the top and bottom, for 2.20:1, because wouldn't a 2.20:1 be able to be bigger on screen, if it's in a 1.85:1 container, rather than a 2.39:1 container, which would be projected smaller on screen, since not as much vertical space is being used on the screen?
Tomorrowland was shot in 2.20:1 but put in a 1.85 container I read, for example, and I thought the reason is, cause the the 2.20:1 image would be bigger in the 1.85:1 aspect ratio.
Old April 20th, 2019, 05:16 AM   #19
That would work as well.
Old April 20th, 2019, 01:37 PM   #20
Sure. Or I could do it in a 2.39:1 aspect ratio with pillar boxing instead, if that's better too :). But if the projectionists stretch the image and distort it to get it to fit, or refuse to screen the movie at festivals, for being 2.20:1, then I can actually shoot the movie in 2.39:1 if that's best.
Old April 20th, 2019, 04:26 PM   #21
I would tend to keep to a standard aspect ratio, but so long as the film has covering note (attached to the media) saying what you're doing and you're working within the standard aspect ratios with your cropping you should be fine.
The projectionist may not see the film before the screening, so I wouldn't do anything too involved.
Old April 25th, 2019, 05:19 PM   #22
Oh okay, well if I have to attach a note and all, maybe I should stick to 2.39:1. So it's pretty much normal then for most indie films to be shot in either 1.85:1 or 2.39:1?
