Small battery powered HDMI to SDI adapter at DVinfo.net
Open DV Discussion
Old February 9th, 2017, 12:55 PM   #1
What would you guys suggest for HDMI to SDI adapters that would be portable, possibly even on camera, definitely battery powered.
Old February 9th, 2017, 04:00 PM   #2
Re: Small battery powered HDMI to SDI adapter
i use these cheap ebay SDI/HDMI converter with a plate adapter for a sony NP-Fxx battery.
works fine for hours.
Take care to choose the right converter since they look the same (hdmi-->sdi or sdi-->hdmi)
Battery Adapter Mounting Plate fr NP-F970 F750 F550 Sony Battery 970 DSLR Rig | eBay
Old February 9th, 2017, 08:54 PM   #3
I've been using a Blackmagic SDI - HDMI mini converter on camera, but they also have an HDMI - SDI version.
Old February 10th, 2017, 12:23 AM   #4
Atomos makes a little one that's powered by Sony NP series batts. Actually they make 2 for the 2 directions HDMI/SDI. About $100 IIRC.
Old February 10th, 2017, 09:41 AM   #5
The Atomos Connect converters run $195 and use Sony-type camcorder batteries.
Black Magic now offers "Micro" converters for HDMI > SDI and vice-versa, $85 each. They have a micro USB port for power, so one can use any of those inexpensive battery packs meant for recharging cell phones. AC adapter included.
Jeff
Old February 10th, 2017, 10:40 AM   #6
Ah lots of great solutions! Thanks guys, I'm going to give a couple of them a try.
Cheers!
Old June 1st, 2017, 11:18 AM   #7
I figured out this was a way to mount my Atomos Connect to my Canon XF 300. The good news that I discovered yesterday, is that same flat screw you see (that I cut short with a saw) screws into my DSLR setup
Albiet my Atomos/setup is not working at the moment, at least it's pretty on the setup. :}
Small battery powered HDMI to SDI adapter-mount2.jpg   Small battery powered HDMI to SDI adapter-atamos-nikon.jpg
Old August 6th, 2017, 09:46 AM   #8
Sponsor: Camera Motion Research
The Feelworld (Seetec) converters also have a Sony NP battery plate built in.
Nice construction includes 1/4-20 mounting holes.
Camera Motion Research Amimon Connex Wireless Antenna and Transmitter
Rich Greb
CMR
Rich Greb is offline   Reply
