Can I enable Quick Sync Video on this OLD PC?
I was able to follow the development of computers... until a few years ago. With the diversity nowadays, one needs to be a computer engineer to keep up.
I built this machine myself back in 2010. It served me well and it's still working perfectly fine. Most of my deliverables are MPEG2, and I edit on Edius Pro 8. Some of my clients started asking for MPEG4/H.264, and where Edius is 4-5 times faster than RT with MPEG2, it takes RT or a bit more for H.264. My question is: Is there a Quick Sync capable graphics card that will work in this computer? I do have a decent laptop that is capable of taking advantage of Quick Sync (H.264 encoding is about 5 times faster than RT), but it would be nice to have the workstation doing the same. I KNOW IT'S OLD, NO NEED TO RUB IT IN... just trying to get a little more out of it. Mobo: Asus P6T Deluxe V2 CPU: Intel Core i7 920 @ 2.67 Ghz RAM: 12 GB DDR 3 GPU: don't ask... Edius didn't need anything fancy until now. OS: Windows 10 Pro, 64-bit Thanks for the help, |
Re: Can I enable Quick Sync Video on this OLD PC?
Don;t knock it if it's still working.
Check out the GeForce 600 series, it may be suitable, since it performs video encoding in a a similar way. Nvidia may be able to give a more precise answer, |
In short, no, quick sync will not work with a i7 920, you need a cpu with integrated graphics, my i7 4790 has that and also the new i7 6700 so getting a faster graphics card won't make any difference.
If you do a lot of colorcorrection however then a separate graphic card makes sense because since version 8.22 Edius makes use of a card for it's primary color correction filter. |
Edius doesn't make use of a videocard for accelerated h.264 rendering.
#5 |
Equal Opportunity Offender
Something like the Matrox Compress HD might help.
See Matrox CompressHD Technical Specifications I don't think there is direct support for Edius, but you can certainly encode a file that has been previouslyy exported out. I think. (I'm only used to functionality of Matrox stuff when combined with the Adobe software) The really good thing about this card is that it takes on all the mp4/h264 compression grunt work, leaving your CPU alone. This is now a legacy product, but there may be others out there. Andrew |
#6 | |
Edius Pro 8 "... supports Intel Quick Sync Video for extremely fast H.264 export". |
#7 |
QuickSync is a function of integrated GPU on some of Intel processors. So if the Intel processor you have does not have an integrated GPU it does not have Quicksync and consequently EDIUS can not use it for fast h264 export using QUicksync.
Ron Evans |
#8 |
Ah, OK - understood.
Would it make sense to upgrade my processor instead of upgrading the video card? What - if any - Quick Sync enabled processor would work in my old Asus P6T Deluxe V2 mobo? Thanks, |
#9 |
Quicksync processor will require a new motherboard unfortunately. I would now wait until the Z200 chip set boards come out if you want to go that way and then get a Kaby Lake processor. Should come out towards the end of the year if rumors are correct.
Ron Evans |
