Just an idea at DVinfo.net
Open DV Discussion
Old July 1st, 2016, 04:47 PM   #1
Just an idea
But does this already exist ?
I recently picked up a DSR 500 for a bargain price . However , having been used to using newer cameras with flip out LCD screens , it was something of a culture shock to go back to the monochrome viewfinder , good as it is .
After a rummage in the attic , I unearthed a couple of small CRT monitors ( a JVC TM10 and a Sony PVM 6041 ) both of which are useful if shooting from a static position , if a little bit cumbersome .
I know there are plenty of flat panel monitors available these days , but then it occurred to me that most of us now have iPhones , iPads or similar devices , and I wonder if anyone makes a small transmitter which accepts the video output of a camera , and links either by Bluetooth or Wi-FI to enable the image to be displayed on a mobile device ?
I haven't come across such a thing , but it strikes me as simple and obvious , and I'm sure would be quite a popular item .
Derek Heeps is offline   Reply With Quote
Old July 1st, 2016, 10:33 PM   #2
Re: Just an idea
Camranger does this for canon (& Nikon?) dSLRs. Retail $300. It plugs into the USB terminal on compatible cameras.
Teradek has several transmitters hdmi & HD-SDI that can be used to hop to a receiver, or an iPad or such. Very slick, the least expensive I'm aware of is the VidiU for $700.
I'm sure there are others out there. Not sure if there's an SD composite solution.
Old July 1st, 2016, 11:43 PM   #3
Re: Just an idea
Thanks , that's interesting , although these solutions are more costly than just buying a small monitor .
Considering that so many small action cams costing hardly anything have the facility built in , a small transmitter needn't be expensive .
If someone made one which took composite , YC , or HDMI , at a reasonable price , I'm sure it would be popular .
For that matter , if it were possible , even a wired solution allowing , say , an iPad to be used as a field monitor , would be useful .
