Samsung Galaxy Note 4 exposure settings no effect on video
For my first smartphone, I got the Note 4. Of course, I did not expect it to perform like my Panny GH3 or Sony NX5/NX70.
But, it has a very annoying defect, wondering if all Note 4's have the problem. The exposure settings such as ISO , +/- , only affect stills. With video, when using them, on the preview before starting the recording, they seem to be working. And, they work for stills. But as soon as the recording starts, the image on the screen reverts to the default look. For example, if I boost the exposure +2, the preview looks over exposed, and if I drop it to -2, the preview looks underexposed - but neither setting has any effect on the final video. It does not matter which video size or fps is chosen. Again, all is normal for stills. All feedback and comments most welcome! Steve |
Re: Samsung Galaxy Note 4 exposure settings no effect on video
Try looking for LGcamera.
Thanks Donald, but I am confused. Did you mean search DVinfo for LGcamera? I did but found nothing helpful about my problem.
Steve |
#5 |
Thanks Donald;
Before I give up on the built-in Samsung camera app; I want to know if every Note 4 has the problem, or if my phone is defective. Also not sure how a third-party app will work with the specific sensor module in my phone, the Sony IMX240 Exmor RS. Is there a better forum on DVinfo for smartphone video? Steve |
#6 |
Well, I tried the LG Camera app and it is terrible. Ads, does not support the UHD modes on my Note 4, and it crashes a LOT.
I contact Samsung support via chat. Typical offshored frustration, please see below. Still looking for other Note 4 owners who can shed light on this problem. Steve --------- Valyncia: I am sorry to say, it is default with the device. steve crye: Can you please elaborate? Valyncia: Sure. Valyncia: I am sorry to inform you that the exposure values are applicable only for the pictures but not the videos which is the reason why the exposure values are not getting applicable for the recording. steve crye: Can you please provide a link to a document that confirms that? (At that point the chat operator disconnected the chat!) grrrr |
#7 |
Wouldn't surprise me if there eventually is a "shooting with a smart phone" section one of these days... but it's still a very limited number of phones that have halfway respectable imaging capabilities - most are pretty low end quality at best...
The suggestion to try a different "camera" app is worth trying. It may be that the "stock" camera software is limited or buggy (so not "working" for video), but a third party app will access features that are there correctly. You have to think of these "smart" devices differently - there's hardware, which you can't do a lot about, but then there's the software layer, which may (or may not be) able to access the features and capabilities of the hardware in different ways... so what may appear to be a "defect" may just be how a particular app accesses the hardware, while a different app accesses things the way you "expect" it to... It's not unlike those of us who either do or wish to "hack" a specific model of camera at a firmware level to make it do things the HARDWARE is capable of, but were "left out" by the manufacturer for some reason. Obviously you'd "expect" the factory software on a phone or tablet to be able to use the hardware, but I've seen a couple devices with NO "camera" app... but you could easily install one (or several!) Hope that helps make some sense of what you're seeing - it's very likely that the Sony module is capable of doing what you expect, but the factory Samsung "skin" software doesn't work as expected... |
#8 | |
Hopefully someone will write an app that takes full advantage of the Sony IMX240 in the camera. It does take great stills, and good video when conditions are conducive to full auto. I would attach an example but the forum php does not seem to work from the mobile browser I use. Steve |
#9 |
I'm pleased to report the problem has been "fixed."
I should have known better than to waste time with Chat-based support. I email Samsung, and received a nice, grammatically correct reply that led me to the solution - clear the camera app's data and cache. Although this begs the question of why this was needed and how often I will have to do it, I am pleased. Here's a snippet of Samsung's response: ------- Please perform the below troubleshooting steps to resolve the issue and check with the result. Clear the cache and data of Camera application. From the Home screen touch Apps >> Settings >> Applications >> Application Manager >> swipe the screen to left till you see “All” on the top >> select the Camera application from the list >> tap on clear cache and clear data. Then, come back to “All” screen >> touch Menu (located at the top right side with 3 vertical dots)>> tap on “Reset app preferences”. If the issue persists, please reset the Camera. Open the Camera >> touch Settings (Gear) icon >> tap on horizontal dots >> tap on Reset. After that, perform soft reset on the phone. Soft reset refreshes the internal circuitry of the device. 1. Turn off the handset. 2. Remove the battery and wait for 30 seconds. 3. Reinsert the battery and turn ON the device. Generally, performing above steps should resolve the issue. Thank you for choosing Samsung phones. --- Steve |
