Dry erase Markers for film slates? at DVinfo.net
Open DV Discussion
Old October 1st, 2014, 03:02 PM   #1
Can anyone recommend the kind of markers that you can get from
office stores or hardware stores that will work for film slates?
I can't go to film tools, I tried some from Staples one time but they didn't work well.
Joe Riggs is offline   Reply With Quote
Old October 1st, 2014, 04:25 PM   #2
Re: Dry erase Markers for film slates?
Expo chisel tip dry-erase markers. Expo Original Whiteboard Markers | Dry Erase Markers for White Boards
For wet erase (my favorite for semi-permanent marks, like for the date or for focus wheels) Expo Vis-a-Vis fine point wet erase: Expo Vis-à-Vis Markers | Wet Erase Markers for Whiteboards and Overhead Projectors
Edward Carlson is offline   Reply With Quote
Old October 1st, 2014, 09:20 PM   #3
I use the Expo original markers. They are the cleanest erasing on my slate.
The low odor versions of the markers don't erase well at all.
http://www.LandYachtMedia.com
Old October 12th, 2014, 11:02 PM   #4
So I found out why they didn't work on my slate, the slate I have is old and someone used sharpie on it by accident years ago. I cleaned it off then but I can't recall how, however I think in the process I took off the coating that makes the slate dry erase.
Anyway is there a way to get that coating back or reapply it so it will work with dry erase markers properly or is a new slate the only answer?
Old October 13th, 2014, 05:22 AM   #5
How about something like this to cover over the writing surfaces of the slate??
Amazon.com: Scotch Dry Erase Tape, White, 1.88-Inch x 5-Yard: Home Improvement
Chris Medico is offline   Reply
