Flicker
Hi, i have a simple problem but I can not figure out the solution, probably you guys can help me:
I have been shooting 1920 1080 and 1280 720 at 30fps and 24fps and when I do quite slow pans the video flickers. It doesn't happen when I shoot at 60fps. Is that normal?, or is there anything else I should know? My cameras are: Eos t5i and Cannon XA10, the same thing happens with both cameras. I appreciate any help, thanks |
Re: Flicker
Have you read much on panning speed/frame rate/shutter speed combinations?
If not do some searching on your favorite search engine and read up on it. This may get you started: https://www.google.com/search?q=pann...x-a&channel=sb
http://www.LandYachtMedia.com |
Equal Opportunity Offender
Re: Flicker
It might be to do with the shutter speed that you have set. Got some sample footage to share?
Andrew |
