Shooting Video in High Humidity
shooting in humid area
-------------------------------------------------------------------------------- Hi All I think to purchase the Canon mini DV XL2 camera to shoot a documentary film in the Rain forest of Ecuador. I was really worried about the humidity in the area 88%. so I called the canon manifacture and asked about the conditions Guarenteed by canon. Their respond was they Guarentee only until 85% humidity and 104 F. I would like to know if anybody has experience in shooting in high humidity or knows how the XL2 functions at that area because I do not want to take the risk. Also if anybody can suggest another Camera (at That price $4000) that is more suitible for humidity? best Yoram |
Skyonic New York
you may want to skip tape altogther and shoot on a hard drive device like firestore...
I have shoot a lot with the Sony DSR 250 in the Houston Area recently where the heat and humidity has been really bad, though I have never been to a rain forest before. The greatest problem I ran into was going from an air-condition room to outside when water droplets would form almost instantly on anything metal or glass. However, after giving the camera time to acclimate to the climate it preformed well.
If using tape I would shoot something like Sony PDVM-40N in DV SP format, which will give you 60 minutes, or something equivalent. I don’t think the consumer tapes are made to take that environment. Plus the Tupperware like, blue plastic, cases offer for more protection than the clear plastic ones do. |
Standard humidity specs are valid when the equipment is at ambient temperature. All ambient humidity levels are acceptable (even near 100%) as long as the equipment (i.e. camera,tapes,lenses...)are kept (or warmed up) above the ambient temperature.
#5 |
Duplicate & Relative Thread
www.dvinfo.net/conf/showthread.php?t=52326 |
#6 |
Thank you all
Thanx a lot for your recommandations, I think I will stay with the XL2 and protect it as much as possible from humidity using anti humidity chemical 'silica gel' and hair drier.
I just hope to bring good results out of that mess. best Yoram |
#7 |
Silica Gel Packs
I would be very careful using silica gel (dessicant) packs with those beads. If those packs rupture, those little beads will get into every little opening on your gear! I believe B&H sells dessicant packs just for placing in gear cases so those packs may be tougher for that use. Ask to be sure.
Dessicant Packs http://www.bhphotovideo.com/bnh/cont...&shs=dessicant |
#8 | |
