Canon J15ax8B4 lens repair at DVinfo.net
Open DV Discussion
Old March 20th, 2014, 08:57 PM   #1
I have a Canon J15ax8B4 ENG lens with a zoom ring that sticks a bit when rotated. The control handle is not attached so its not the manual switch. Does anyone know of a DIY fix or a good place to send it for reasonably priced repair. I suspect it only needs to be partially disassembled and cleaned but I am not about to attempt that myself.
Jim Snow is offline   Reply With Quote
Old March 21st, 2014, 07:34 AM   #2
Re: Canon J15ax8B4 lens repair
Hey Jim,
You should check around with some of the California rental companies. They might have a lens repair tech locally. Canon has a repair center on the east coast that I have used. I stopped buying Canon 2/3 inch glass for the most part when I found I was returning to the repair shop for rebuilds a little too often for my tastes. Usually the cost of repair is higher than you would like but less than looking for another lens. Good Luck
Daniel Epstein is offline   Reply
