Projection equipment rental Olympia or Seattle? at DVinfo.net
Open DV Discussion
Old February 26th, 2014, 07:39 PM   #1
Greetings,
I hope it's the right place for this kind of request...
I need to rent the necessary equipment to do a screening in a large room (a church in fact), which accommodates +-150 people. I don't have yet the dimensions. In terms of throw, the projector doesn't have to be set up in the back of the room, and can be in the middle aisle to the required distance from the screen. So my question is: could someone recommend a place where I could rent the necessary equipment (projector, screen, speakers). The medium is a DVD, but a BluRay, laptop or thumb drive or whatever can be used if necessary. The event will take place in Olympia, Washington, so a rental place in Olympia, Seattle or Portland would be perfect. Rental dates are the weekend May 31st/June 1st.
Thank you for reading.
L.
Luc Novovitch is offline   Reply With Quote
Old February 27th, 2014, 02:45 PM   #2
Re: Projection equipment rental Olympia or Seattle?
I'd give glazer's a call, and see what they say.
https://www.glazerscamera.com/
Brian McGahuey is offline   Reply With Quote
Old February 28th, 2014, 12:22 PM   #3
Thank you Brian. I'll give them a call.
L.
