Building a simply DIY motorized camera dolly system at DVinfo.net
Open DV Discussion
Old November 21st, 2013, 11:23 AM   #1
contact admin
--- ServoCity's simple DIY camera dolly ---
Want to know what the final outcome will look like and how it can be used? Check out this video review by Cheesycam.com : Simple DIY Motorized Video Track Dolly Project CheesyCam
STEP BY STEP INSTRUCTIONAL VIDEOS AT THE LINKS BELOW
It is now easier than ever to build your own custom dolly. Simply use our new Dolly Wheel Idler Plates to assemble a low friction system designed to work with 1” OD to 2” OD tubing (and any OD in between). We highly recommend using standard PVC pipe that can easily be purchased at your local hardware store.
Dolly Wheel Idler Plates A (585534)
Want to motorize your dolly platform? We have a simple solution. Our new Dolly Wheel Drive Plates make it easy to assemble a low friction drive system designed to work with the Dolly Idler plates mentioned above. The parts will work with most gearmotors that utiltize a 6mm bore output shaft.
Dolly Wheel Drive Plates B (585536)
Lauren Lewis is offline   Reply With Quote
Old November 21st, 2013, 11:57 AM   #2
Re: Building a simply DIY motorized camera dolly system
From a glance through the page on your link, looks like some pretty cool stuff. Thanks for sharing. I must admit though, the pictures that I saw of the Dolly, at first I was thinking it totally reminded me of thinking built from an Erector Set. :)
Ralph Gereg is offline   Reply
