Thread Tools
Search this Thread
Question about 1080i
I shot a 30 second promo that will be airing on TV. I shot it on a dslr at 1920x1080 30P. For HD the station prefers a file that's either 720p or 1080i. Since I shot in a progressive mode, can I actually export 1080i without a problem? I did a test of it and it looks fine. If this cant be done, how to I actually export a 1080 file that was shot in a progressive mode?
#2 | ||
Re: Question about 1080i
Point is that what Wikipedia then refers to as segments can be considered the same as fields in an interlaced signal and treated as such. To a transmitter etc, I and psf are the same. Difference is that all the lines in a psf frame are captured at the same time. With a true i signal the lines in each field are captured 1/60 second apart. Hence 1080psf/30 has the same "look" to motion as 1080i/30. |
Dave thanks for the info. Just for further clarification, I can render the 1920x1080p to 1440x1080 60i with no problem correct?
Yes you can export 1920x1080 (1.0 PAR) to 1440x1080 (1.333 PAR), but can I ask why you would want to create an anamorphic file - is that what the TV station requested?
Jeff Pulera Safe Harbor Computers |
