Bags / Cases at DVinfo.net
Open DV Discussion
Old June 19th, 2013, 08:57 AM   #1
Bags / Cases
Is there any bag or case that will hold my camcorder and dslr? My camcorder is the size of a standard HDV camera eg V1, XHA1 etc
Matthew Chambers is offline   Reply With Quote
Old June 19th, 2013, 09:09 AM   #2
Re: Bags / Cases
I took a beloved hard case rolling luggage that I had, and fit in custom foam to hold everything. Lots of pockets for everything, too.
Old June 19th, 2013, 10:56 AM   #3
Re: Bags / Cases
You might look at the Porter Case. Someone here had a link but I can't find it at the moment.
I use a Pelican iM2650 for my JVC HM700 and all of my accessories. I can pull the camera out of the case and start shooting. Batteries, light with batteries, all my audio, cards, small roll of gaff tape, headphones, it's all there. A bit unwieldly loading in my car but a pleasure to wheel around thru hotel lobby's and downtown Chicago streets. The Porter was an option except for the size. For my gear it was a bit small but it might work for you.
Don
Old June 19th, 2013, 12:28 PM   #4
Re: Bags / Cases
There are a couple of requirements to consider:
1) Do you want the bag/case to be small enough to carry-on for air travel? Should it fit under the seat?
2) Do you want the bag to be a backpack so you can do solo shooting without having to set it down and risk theft.
There are some camera backpacks that might work for this. I have the LowePro Fastpack 250, which holds a DSLR, lenses, stores a laptop near your back, and has a general, unpadded area on top. It fits under an airline seat - barely. They also have the ProRunner that is padded top to bottom. By structuring the velcro'd dividers, one could handle multiple bodies, though fewer/smaller lenses.
Fastpack 250 Camera bags, backpacks and rolling cases
Pro Runner 350 AW Camera bags, backpacks and rolling cases
When I first started DSLR shooting, I used a small Pelican case and quickly learned that it was insecure to set it down and turn my attention to framing video. Carrying a nondescript black backpack is ideal.
But if you have more gear and even a two man crew, Pelican is a nice way to go - especially a case with a handle and wheels. It's perfect for throwing into a trunk or van.
Personally, I like having both the hard case and backpack options. :)
Jon Fairhurst
Old July 25th, 2013, 09:59 PM   #5
Re: Bags / Cases
Pelican and Nanuck make protective cases which are nice cause they protect you camera gear more than soft padded cases.
Independent Filmmaker in Canada's Capital
Graeme Hay is offline   Reply
