#16 |
Re: Best inexpensive green screen camera
Jon, did you see the followup email I sent you with a screen shot done with much better lighting? Do you consider that example noisy?
#17 |
There is a fairly long thread older thread about green screen, external recorders, and 4.2.2 on dvxuser.com. I don't know if you read it, but what I took away was with the external recorders there was an added noise which did not help in keying. The problem is the camera(s) tested were older and I have no idea about all the other technical stuff they were talking about. Its a bit surprising someone has not done a camera shoot out on the cameras you listed.
#18 | |
What keying software are you using? Because if you are not using The Foundry's Keylight, you definitely need to give it a try.
Keylight is included in all versions of Adobe After Effects, but it is also available as a seperate plugin for all major NLE programs. The seperate plugin costs around 300 USD and is really worth its price. With keylight you can do nice greenscreen work even with consumer-type AVCHD camcorders (4:2:0 with only 28mbit/s). So, before you spend a lot of money on new camera gear, I'd suggest you first try the best software keying solution and then decide what more and better equipment you need. About three years ago I was tasked with some regular green screen work and the cameras available were all 4:2:0. That is why I tested all available plugins and keyers, BorisFX, Motion, can't remember all of them, it were at least six. The only one that came close to keylight was BorisFX, but it still lost in a direct comparison. Really, try it! It is in a whole other keying league than 90% of all other software keyers! Quote:
In that case the signal recorded by the external device is still better, only it needed some denoising. However, I'll say it again... if you don't use Keylight, you should. I sound like a sales rep, but believe me, I am not. I am just extremely convinced by this keyer's capabilities, and no one so far was able to show me a better one (not even an equal one!) |
#19 |
If you're on any sort of budget, it's still hard to beat an old used HVX/HPX for key work. Low light was always their weakness, which isn't an issue in a key setup
#20 | |
#21 | |
BTW, I just bought my wife a Canon Vixia R400 camcorder for $250 for her new solo vlog project. The R400 was the cheapest HD camcorder with an external mic input that we found - and no way would she be happy finagling a DSLR. Craigslist was no help. There are delusional people out there asking up to $400 for old SD DV cams. :-/ Anyway, I'll be curious to record the HDMI output just to see what it delivers. Could it surprise me and be 4:2:2?
Jon Fairhurst |
#22 |
@Heiko: Thanks for the review on Keylight. My son did the compositing with AfterEffects, probably using KeyLight. With the DSLR, we didn't have an issue with noise and clean keys. The main issue is softness. From experience, while you can get a clean key with 4:2:0, you can't get a crisp key until you go 4:2:2 or 4:4:4 (drool). Also, grading is critical for our work, so more bit depth is desirable. Keylight might do the trick, but we still want the best camera for the job within budget.
@Kevin: The HVX200(a) and HPX170 are 720p cams. We're interested in 1080p24 or better. The HVX500 would be awesome, but used models with lenses seem to go for around $10k. No surprise for a 2/3" pro model. A very desirable camera indeed! @Steve: Yeah, the noise could be from bypassing the NR, from a technical issue, or from the compression in the recorder. Unless you're recording to a RAID, recorders typically compress the video.
Jon Fairhurst |
#23 |
From my experience, I don't see any camera below the Sony EX1/3 or Canon XF300 series class that can give you footage with edges (red in particular) clean enough for keying without the end result looking faked on general 1080p displays. On cell phone screens or old interlaced CRT sets it might be acceptable. The Panasonic HVX/HPX series may be workable a step down in pricing/IQ terms but I think the resolution hit is significant thus making your job all the harder.
#24 |
Yes, the EX1/3 and XF300 both have three CMOS sensors. The XF100 is a definite step down with a single Bayer sensor, though it seems it has the same 50 Mbps 4:2:2 codec as the XF300.
Looking again at our project, it's possible that we will rent. We're likely to spend most of our time writing, making props and costumes, and doing post/marketing work. If we schedule things well, we can limit our shoots to one or two weekends per month, making a rental realistic. Okay. LET'S CHANGE THE RULES ...to include cameras that can be rented for under, say $150/day. That puts the XF300 and EX1 in the lead. The advantage of the XF300 is that no external recorder is needed. The advantages of the EX1 are the larger 1/2" chips and potentially 10-bit depth(?) on an external recorder. Anything else in that rental class?
Jon Fairhurst |
#25 |
It looks like other rent-with-a-recorder options might include the Panasonic AG-HMC150PJ, AG-AC130A and AG-AC160A, which all shoot 1080p24.
The HMC150PJ is a 1/3" 3-CCD camera with HDMI and no HD-SDI. The AC130A and AC160A have1/3" 3MOS sensors and include HDMI. Step up from the AC130A to the AC160A to get HD-SDI. The HDMI and HD-SDI outputs are not clear. They list 1080i60, so I assume that 24p is handled with pulldown. But are the outputs true 4:2:2? Are they 10-bit outputs? The advantage of the Canon XF300 is that it's 100% clear that it records 4:2:2, though with MPEG-2 it will be at 8-bits. The EX1/3 and the Panasonic cams above might output 10-bits, but then again they might not even put out 4:2:2. It would be good to be able to nail down the outputs of the various cams. Stepping up in price, Panasonic offers the AG-HPX250PJ. This looks killer. It records 100mpbs 10-bit 4:2:2 AVC-Intra. Of course, for 10x the price, one can rent the AJ-HPX3700 and get 4:4:4. Okay, on paper, the HPX250PJ looks like the ideal rental. Three chips. 100mpbs 10-bit 4:2:2 internal recording. List price is $6,355.00, which should be around the $150/day range, if it's locally available.
Jon Fairhurst |
#26 |
Checking with one of the main rental houses in Portland, OR, USA, they don't have the HPX250, but they do have the Sony PMW200. This records 4:2:2 at 50 mbps (8-bits) and has three 1/2" chips.
Unfortunately, the rental price is $250/day. What's worse, they are now adding a 50% penalty for Friday (weekend) rentals. After three rentals, I will have been able to buy a BMC Pocket cam for RAW (although 1080p Bayer) shooting.
Jon Fairhurst |
