30P to Blu Ray? at DVinfo.net
Open DV Discussion
Old March 18th, 2013, 06:16 PM   #1
30P to Blu Ray?
I filmed a project on a Canon XHA1, 1080i 30P. Can this footage be burned to Blu Ray without a problem? From what I understand 24p and 60I are actual Blu Ray specs.
Kevin Lewis is offline   Reply With Quote
Old March 18th, 2013, 07:16 PM   #2
Re: 30P to Blu Ray?
Normally it would be converted to 60i, since 30p is not a directly supported Blu-ray format. x264 gives the option to flag the progressive frames as interlaced so the disc can be encoded as progressive. You have to check whether your Blu-ray authoring software will thereafter support using the reflagged 30p.
Old March 18th, 2013, 08:08 PM   #3
Re: 30P to Blu Ray?
Hey Kevin...
The XHA1 shoots 60i, 24P and 30F.
You didn't mention any encoders. Since i use AME, it defaults to encode your 30P output as 29.97.
So yes, it will work. I do it all the time.
Peter Manojlovic is offline   Reply
