mount similar to this? at DVinfo.net
Open DV Discussion
Old March 12th, 2013, 07:44 AM   #1
I'd like to find something like this....
Accessory Mounting Block, Tapped 1/4-20 w/Knob | | Berkey System
with multiple mounting holes, that splits in half so it can be put on a tube that has permanent, larger ends on it.
Anything come to mind?
Philip Fass is offline   Reply With Quote
Old March 12th, 2013, 12:20 PM   #2
Re: mount similar to this?
I don't know much about this kind of rigging, but I happened to come across this, if it helps:
Swiss Rod 15mm Rail (2pc) by PNC | Photography and Cinema - Store
Old March 12th, 2013, 05:26 PM   #3
Sounds like you're looking for an articulating arm clamp. They come in different configurations. The photo on the right shows one with a 3/8 and 1/4 hole. Or if something a little smaller, the other clamp has two 1/4 holes and is designed for 15mm rods (available at CoolLCD).
mount similar to this?-quick-release-single-rod-clamp-railblock.jpg   mount similar to this?-magic_arm_11_with_clamp_5.jpg
Old March 13th, 2013, 04:14 PM   #4
B&H have a huge range of 15mm mounting accessories. At least 14 pages from what I can see
Rod Brackets & Adapters| B&H Photo Video
Stills at: www.flickr.com/photos/trevor-dennis/
Trevor Dennis is offline   Reply
