AVCHD Problem at DVinfo.net
Open DV Discussion
Old March 8th, 2013, 07:28 AM   #1
AVCHD Problem
Hi I have Ultimate and a powerful PC. Before I was able to edit these HD files easily, now all of a sudden when I load them on VS5 I can hardy edit them, even when I just want to play them when they are in the timeline.
What steps must I take and where to look. This PC is only used for editing and nothing else.
stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old March 8th, 2013, 08:19 AM   #2
Re: AVCHD Problem
Hi Stelios
The first thing to do is decide what has changed. If your files have changed (maybe a higher bitrate) or maybe you are running multiple clips on the timeline ..both will slow down the process.
Assuming your PC is not bottle-necking somewhere and everything is still the same then how about same basic specs on the computer. I'm running Win 7 -64 bit on a 3.4GB i7 machine and 8GB ram and previews run pretty much OK and my renders from 1920x1080 down to MPEG2 SD take around 1/3rd realtime so if your performance is a lot slower then the computer might be slow for some reason ..fragmented drive maybe?? I render from a USB2 external drive with no issues. This is using Sony Vegas 10 64 bit.
Bottom line is that you need to isolate the problem first ..Is it your NLE, your files or your computer that's causing the problem??
Chris
Old March 8th, 2013, 09:23 AM   #3
Re: AVCHD Problem
Hi Chris
No I am not running multiple clips These clips are on a separate hard drive and when I play them (wirh any player) the play 100%
My PC specs are Win 7 Pro 64 bit
Intel Xeon CPU 3.30 HZ 16GB RAM
stelios
LATEST NEWS.
I have tried it now today and everything is working fine. What happened?
Old March 8th, 2013, 06:09 PM   #4
Re: AVCHD Problem
Sometimes it's a good idea to simply shut down the computer and restart it..On that particular boot up anything could have not loaded correctly, the operating system or your NLE so you will probably never know.
Just be happy it's all working again!!
Chris
Chris Harding is offline   Reply
