Frame rates at DVinfo.net
Open DV Discussion
Old January 28th, 2013, 01:04 PM   #1
Frame rates
Hi gang. I'm somewhat new to digital editing & I need some help on the technical side. I've changed camcorders and where I had been shooting 1080p 30 fps, I no longer have that option. Now I have either 24 fps or 60 fps. iMovie doesn't seem to accept 60 fps - or, rather, seems to convert it to 30 fps anyway.
So, I'll most likely be shooting at 1080p 24 fps from now on. So when I edit my footage together I just start a new project at 24 fps and leave it at that? No other concerns? Or should I make my project 30 fps, which seems to be the standard that I see? I don't understand WHY I'd choose one over the other.
Where can I learn more about the technical side? I understand shooting (composition, lighting) and I understand the storytelling idea of editing, but I'm weak on the technical side - codecs, frame rates, key frames, etc.
Darryl
Darryl Jensen is offline   Reply With Quote
Old January 28th, 2013, 03:03 PM   #2
Re: Frame rates
What's your intended end product Darryl? And will you mixing footage from the two cameras in the same project?
Stills at: www.flickr.com/photos/trevor-dennis/
Trevor Dennis is offline   Reply With Quote
Old January 28th, 2013, 05:35 PM   #3
Re: Frame rates
A few intended end products: DVD, HD Vimeo, HD TV. DVD mostly, but I do like HD output as well.
Yes, I would very likely be mixing footage from other cameras - 1080p 30 fps would be one alternate for sure. Could be others.
I shoot everything in 1080p so that I can recompose, tilt, pan & zoom in post-production without losing quality, editing down to a 720p final. If there's not too much zooming, I would stay in HD.
