Video Mixer Software for Live Streaming? at DVinfo.net
Open DV Discussion
Old January 2nd, 2013, 03:55 PM   #1
Hi,
Our nonprofit is looking for video mixing software that will send the output to a software encoder for live streaming, unless the product we want can do all in one mixing, encoding, and streaming.
All we need to do is fade back and forth between a still image and an HDMI signal from a camera. We'll also have a stereo audio signal going in to the encoder. Currently we use a Blackmagic capture card in a HTPC and Kulabyte, but it's possible we may have to get a different box since we'll be switching streaming companies.
What would be the best software to do this that's also a cost effective solution? I did a bit of looking around and Telestream Wirecast seems to be pretty good for this without being too expensive.
Let me know, thanks!
David Horwitz is offline   Reply With Quote
Old January 2nd, 2013, 06:26 PM   #2
Re: Video Mixer Software for Live Streaming?
I like wirecast! I'm using it with a Blackmagic Designs Intensity capture card, and used to do a lot of firewire capture with it too.
Do check out the trial version and see if it works for you.
Unless you have just a small handful of viewers, streaming distribution is going to need to be done outside your encoding box.
One good thing that you've probably realized - if you build a box on a standard PC using a software encoder it's upgradeable when you want it to be, and can create just the stream you want. Many dedicated systems are more limited in their capabilities. As a boutique webcaster, that means a lot to me; I have to integrate my services into many clients' infrastructures.
For you it may be different - all-in-one streaming boxes do offer a high level of integration and ease of use.
Old March 7th, 2013, 04:47 PM   #3
Thanks Seth for the recommendation. We've been using a different set up for the time being, but I'll keep Wirecast in mind if this crops up again.
