VHS to HD transfer service? - Page 2 at DVinfo.net
Open DV Discussion
Old September 10th, 2012, 03:04 PM   #16
Re: VHS to HD transfer service?
I only do vhs transfers where the client want's a lot of work to make them look as good as possible. As mentioned there is a lot that can be done but to get it to look good in today's HD world it takes a lot of time because you're not able to apply "auto" correction tools. Because of the low cost options I can't compete with the "Costco" type of transfers but if someone wants a high quality transfer my workflow is to use a Panasonic AG-7750 deck ingesting with a Blackmagic Design Declkink HD Extreme. That gives me the best starting point. Then it's a long process of clean up.
I have done other projects where the edit incorporates old footage wither form VHS or even 16mm film. For those, I like to actually go the other way and make it very clear that it is old footage being cut in. It gives a nostalgic feel and because it's apparent that it's from old footage, nobody expects it to look that good.
Garrett Low
www.GLowMediaProductions.com
Garrett Low is offline   Reply
