Video streaming at DVinfo.net
Open DV Discussion
Old August 17th, 2012, 07:10 AM   #1
Video streaming
I work for a local broadcasting network in The Netherlands. We work on a low-budget, you'll rather say 'No Budget' and now we're looking for a solutions to broadcast live from locations outside our studio. This obviously means that we somehow got to send video and audio signal from that outside location to our studio. The cheapest solution that also works now, is to stream the signal using a client like Ustream from the location and pick that stream up with another computer, and put the display through a Scan converter and subsequently broadcast that signal. Now that is an option that would work for us and our empty wallets(Unless you know any other cheap solution).
To finish it up, we're looking for a Streaming client wich has the option to stream only inside a server or it's own software, meaning that the broadcast signal picked up at the studio doesn't have to come from a website like Ustream.
Does anybody know if there is such a piece of software available on the market? Oh, and it doesn't have to be free. ;-)
Regards from Holland,
Jasper
Jasper Pieterse van Wijck is offline   Reply With Quote
Old August 17th, 2012, 07:16 AM   #2
Re: Video streaming
You can use VLC Media player to set up a private stream between 2 clients on an intranet. It is free.
http://www.LandYachtMedia.com
Old August 17th, 2012, 09:03 AM   #3
Re: Video streaming
Jasper
We had a similar discussion a few weeks ago here: http://www.dvinfo.net/forum/flash-we...ebcasting.html
Check out Telestream Wirecast.
Old August 18th, 2012, 08:04 AM   #4
Re: Video streaming
Where can I find an easy manual to get VLC to do this? Because I have to select a file I want to stream but in this case the video comes from a live feed inputted via a Blackmagic capture card.
Old August 18th, 2012, 08:08 AM   #5
Re: Video streaming
Free and simple rarely go together. This is especially true with video streaming.
Read over the "HowTo" here:
VideoLAN Streaming Howto
That is the most comprehensive documentation I am aware of.
Old October 7th, 2012, 06:20 AM   #6
Re: Video streaming
Well, VLC only streams over an LAN network, in this case the we're on a location outside the building where the MCR is located so we're relying on the WAN network available at the location. In most cases the connection available is a Fiber connection.
Old October 7th, 2012, 06:41 AM   #7
Re: Video streaming
If you have fiber to WAN then setup a VNC tunnel. VLC point to point streaming can be done over a VNC connection. Probably a reasonable thing to do anyway to keep it a private connection.
Old October 7th, 2012, 11:13 AM   #8
Re: Video streaming
You forgot to add RELIABLE...
Old October 7th, 2012, 12:44 PM   #9
Re: Video streaming
almost any encoder that can stream to network is able to stream to a particular address.
you just need to make sure the endpoint is set up correctly.
flash live encoder, vlc, windows media encoder, to name a few are ok.
you can even decide to go for harware solution, a small box at each end, video video composite in and out.
the main problem is to get a reliable connection (streaming is very finnicky about packet loss) and the necessary bandwidth. Some encoders do not like network cuts, because you have to reinitiate the full connection.
I would recommend windows media encoder, since it is free and works great. VLC is ok too, but the lack of interface require to fiddle with cryptic commands. You can find many usb dongle that can accept an SD video input. If you need to go HD, it is a bit more complicated to set up on a laptop.
in 2010 the satellite KASAT was launched and now there is a new service lauched called Tooway that offer high bandwith for very cheap (less than 50 euros per month for a 4Mb up link)
they started this year in France and now in Switzerland, but the satellite covers europe.
so for cheap you can get a dish and modem to feed your office with live video.
Old October 8th, 2012, 03:35 AM   #10
Re: Video streaming
Problem remains, when I receive the stream in the MCR. How could I possibly output it to an SDI signal without using a scan converter to duplicate the computer's screen. So I'm searching for software which can output to a SDI capture card, like the BM Decklink SDI.
Old October 8th, 2012, 08:00 AM   #11
Re: Video streaming
If the computer has DVI or HDMI output you only need this box to convert it to SDI.
Blackmagic Design Mini Converter HDMI to SDI CONVMBHS2 B&H Photo
Chris Medico is offline   Reply
